reddeath Posted September 27, 2012 Share Posted September 27, 2012 What is grounded to the dizzy on a 95? Anybody have preferred spark plug in the pathy? Link to comment Share on other sites More sharing options...
Alkorahil Posted September 27, 2012 Share Posted September 27, 2012 If you are refering to the black plug on the front/side of the distributor that is where the tachometer gets its signal from. Use regular NGK plugs only. numbers BKR6EY or (BKR5EY or BKR7EY if you want) Link to comment Share on other sites More sharing options...
Precise1 Posted September 28, 2012 Share Posted September 28, 2012 Standard NGK Plugs are listed as BKR6ES on their wedsite. BKR6EY # is the V power... I run BKR6EGP. What's wrong with them? B Link to comment Share on other sites More sharing options...
adamzan Posted September 28, 2012 Share Posted September 28, 2012 The G-power ones are just platinum. I've run both, they perform the same but the G ones last longer. 1 Link to comment Share on other sites More sharing options...
reddeath Posted September 28, 2012 Author Share Posted September 28, 2012 Cool thanks, my tach doesn't work, but that wire is broken, will fix it when i do the cap/rotor/wires/plugs this weekend Link to comment Share on other sites More sharing options...
MadMax2 Posted September 29, 2012 Share Posted September 29, 2012 NGK wires too if you can, nothing makes me happier than seeing NGK plug wires under the hood. Link to comment Share on other sites More sharing options...
RF600 Posted September 29, 2012 Share Posted September 29, 2012 (edited) I was talking with a tech from Nissan and he recommended not using platinum plugs. There were platinum plugs in when I did my last tune up. I didn't have any problems with them. I put regular plugs back in. Edited September 29, 2012 by RF600 Link to comment Share on other sites More sharing options...
Tungsten Posted September 29, 2012 Share Posted September 29, 2012 Theoretically copper will conduct better than platinum but copper will not last as long. I run platinum plugs and have no issues with them. G-powers are nice plugs. I would run V-powers if I had better means of changing the plugs every 5 oil changes. Link to comment Share on other sites More sharing options...
