TrailChaser Posted February 6, 2006 Share Posted February 6, 2006 I've been thinking that I broke the timing belt for the last 3 weeks... Turns out the little screw that holds the rotor to the shaft fell out. That little screw just saved me $1500. I screwed it back in and the ol girl cranked right up. Link to comment Share on other sites More sharing options...
Simon Posted February 6, 2006 Share Posted February 6, 2006 NICE!!! That's a pleasant surprise!!! Link to comment Share on other sites More sharing options...
El Pathfindero Posted February 6, 2006 Share Posted February 6, 2006 '93 SE 225,000 miles Rear window struts startin to sag Stops need greased needs a tune up/ fluid change tires are almost 100% bald no rear hatch unlocker switch foglights burnt out L headlight has no hi-beams no driverside sunvisor Trim around all vents are broken Rust under back seat Rust between wheelwell and rear doors the usual exhaust tick no spare tire or spare tire carrier no jack center console is loose hole in center console where a switch of some sort was 4-wheel drive light doesnt work door locks work when they want to cowl vents are broken elastic basket-thingies on back of seats no longer elasticky passenger side fender is caved in (the deer is dead tho) front left and right rear speakers are blown t-stat is dead heater only works on auto, 1, and 2 heck of a list, but its all minor stuff Link to comment Share on other sites More sharing options...
ILoveMyPatty Posted February 12, 2006 Share Posted February 12, 2006 1990 SE 197,000km I've got some bada$$ speed wobble goin on.... I haven't had the time to get the front end checked out yet, my insurance ran out, waiting to sell my bike to get money for it. So I'm gonna use the time to throw in a BL or the JGC swap and UCAs. The speed wobble is pretty dang wierd, but if I turn it to the "sport" suspension, it goes away... Drivers side front window sticks going up. Rust on the rockerpanel, right at the front of the drivers door, corner, spot, thing... it goes all the way thru. Clifford security system is hooped. Doesn't allow me to start the vehicle. (thought it was the starter at one point which forced me to replace it with a new one)... After installation, it still wouldn't start... Figured out all I had to do was pull the fuse for the alarm and it would start. Stupid immobilizer thing. Seems like my power steering is starting to go... doesn't like turning when it's not moving. Fixed problems: Broken manifold stud removed and replaced New clutch, after throwout bearing decided to give up on me Gah, the joys of having no job- no money- no way to fix the problems Wahhhhh Although, I am fortunate that they aren't too major... anymore, the clutch was bad.. Link to comment Share on other sites More sharing options...
RedPath88 Posted February 12, 2006 Share Posted February 12, 2006 Blowing White smoke till the engine gets warm.. not sure why! Blown head gasket? Perhaps the expansion of the block/head is sealling a slight leak between a water jacket and a firing chamber, after it warms up? I know, not likely but it's a shot in the dark PS Sun visor Wont stay up Sorry *snicker* Link to comment Share on other sites More sharing options...
