looking for weatherproof screw together connector
ahardb0dy
I'm looking for a male/female type screw together weatherproof connector that I can mount in my roof for my lights, looking to see if anyone has any recommendations, prefer a metal connector, and also would be good if I could put my own wires into the plugs.
Thanks
I've been looking for some bulkhead connectors too for when I put lights on top. I talked to a friend of mine that builds fire trucks and he mentioned this place. http://www.austinhardware.com/ I haven’t had time to search their web site yet. He also told me that when they need a lot of wires through the roof they just use a grommet and silicone! I'm not putting silicone on my roof. We need bulkhead connectors that can handle some decent amperage. Most that I find are for small gauge wire.
James
I found the perfect connector, went thru their whole process online of picking out what I wanted and got to the end and it said, just for one half it would be like $77 !!! I was a little surprised !! so I'll keep looking, this is what I was looking at:
http://www.milnec.com/drawings/ps/ps-series-catalog.pdf
I need a plug with at least 4 terminals, want to keep it clean by having all connections in one. I know of Anderson connectors but I think they only have 2 terminals. Thanks
The anderson connectors clip together in whatever config you need. I believe their larger panel connector does 8 connections, so up to 4 sets of lights. I use them on my electric trike and to extend a charge connections on my motorcycle.
They do sell a water proof plug that does 4 wires/connections, but it isn't a panel option. I haven't found them hard to water proof either.
http://www.milnec.co...ies-catalog.pdf
I knew they wouldn't be cheap. That would be the perfect connector you need. Get one with a few extra terminals so your set if you add things later. I'm book marking this link for later.
James
