ahardb0dy Posted June 28, 2012 Share Posted June 28, 2012 I'm looking for a male/female type screw together weatherproof connector that I can mount in my roof for my lights, looking to see if anyone has any recommendations, prefer a metal connector, and also would be good if I could put my own wires into the plugs. Thanks Link to comment Share on other sites More sharing options...
Slartibartfast Posted June 28, 2012 Share Posted June 28, 2012 You might look at the plugs used for hobby R/C batteries. I'm sure a Tamiya or similar battery hookup could handle a couple lights. Link to comment Share on other sites More sharing options...
JamesRich Posted June 28, 2012 Share Posted June 28, 2012 I've been looking for some bulkhead connectors too for when I put lights on top. I talked to a friend of mine that builds fire trucks and he mentioned this place. http://www.austinhardware.com/ I haven’t had time to search their web site yet. He also told me that when they need a lot of wires through the roof they just use a grommet and silicone! I'm not putting silicone on my roof. We need bulkhead connectors that can handle some decent amperage. Most that I find are for small gauge wire. James Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 28, 2012 Author Share Posted June 28, 2012 I found the perfect connector, went thru their whole process online of picking out what I wanted and got to the end and it said, just for one half it would be like $77 !!! I was a little surprised !! so I'll keep looking, this is what I was looking at: http://www.milnec.com/drawings/ps/ps-series-catalog.pdf Link to comment Share on other sites More sharing options...
silverton Posted June 28, 2012 Share Posted June 28, 2012 what's wrong with butt splice connectors that come with heat shrink wrapping? it's what I used when I did the hardbody headlight swap. Link to comment Share on other sites More sharing options...
Harbinger Posted June 28, 2012 Share Posted June 28, 2012 What about anderson connectors? I know they offer a few panel mount options, and the smaller connectors are good up to 45 amps. They are a bit spendy, but I really like them. www.powerwerx.com Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 29, 2012 Author Share Posted June 29, 2012 I need a plug with at least 4 terminals, want to keep it clean by having all connections in one. I know of Anderson connectors but I think they only have 2 terminals. Thanks Link to comment Share on other sites More sharing options...
Harbinger Posted June 29, 2012 Share Posted June 29, 2012 The anderson connectors clip together in whatever config you need. I believe their larger panel connector does 8 connections, so up to 4 sets of lights. I use them on my electric trike and to extend a charge connections on my motorcycle. They do sell a water proof plug that does 4 wires/connections, but it isn't a panel option. I haven't found them hard to water proof either. Link to comment Share on other sites More sharing options...
JamesRich Posted June 29, 2012 Share Posted June 29, 2012 I found the perfect connector, went thru their whole process online of picking out what I wanted and got to the end and it said, just for one half it would be like $77 !!! I was a little surprised !! so I'll keep looking, this is what I was looking at: http://www.milnec.co...ies-catalog.pdf I knew they wouldn't be cheap. That would be the perfect connector you need. Get one with a few extra terminals so your set if you add things later. I'm book marking this link for later. James Link to comment Share on other sites More sharing options...
ahardb0dy Posted June 29, 2012 Author Share Posted June 29, 2012 I'll have to e-mail them to see if they have a less expensive line of products. Link to comment Share on other sites More sharing options...
tmoore4512 Posted June 30, 2012 Share Posted June 30, 2012 At a former job I had we used this brand and type of connector. I have a female end of one three conductor weatherproof unit, but cannot find a male to go with it.... Here is the link http://e-catalog.beldensolutions.com/link/57078-24228-24351/en/conf/0 Link to comment Share on other sites More sharing options...
