arista5 Posted February 21, 2012 Share Posted February 21, 2012 anyone know if the warns will work with my stock wheels? I will be buying a new set when my tires get a bit more worn. for now will the warn or other brand locking hubs fit under my stock SE wheels? I dont mind removing the center cap. thank you Link to comment Share on other sites More sharing options...
Timmons Posted February 21, 2012 Share Posted February 21, 2012 anyone know if the warns will work with my stock wheels? I will be buying a new set when my tires get a bit more worn. for now will the warn or other brand locking hubs fit under my stock SE wheels? I dont mind removing the center cap. thank you Can you take a picture of your rims? Before I bought my rims, I made sure the Warn lockers fit inside the hubs first. Link to comment Share on other sites More sharing options...
arista5 Posted February 21, 2012 Author Share Posted February 21, 2012 Thank you Link to comment Share on other sites More sharing options...
TShep704 Posted February 21, 2012 Share Posted February 21, 2012 oh yeah, youll be good. Link to comment Share on other sites More sharing options...
Timmons Posted February 21, 2012 Share Posted February 21, 2012 No problem, those will work. Link to comment Share on other sites More sharing options...
accurrate1 Posted February 21, 2012 Share Posted February 21, 2012 It will not work, found out the hard way... Link to comment Share on other sites More sharing options...
arista5 Posted February 21, 2012 Author Share Posted February 21, 2012 (edited) It will not work, found out the hard way... will they fit if the cap is off? Whew, ordered them and was able to cancel after seeing this. Edited February 21, 2012 by arista5 Link to comment Share on other sites More sharing options...
accurrate1 Posted February 21, 2012 Share Posted February 21, 2012 My ride was 02 LE, was tried to install worn hub but the center of the wheel was too small. You need to either bore it out or get new rims. Link to comment Share on other sites More sharing options...
arista5 Posted February 21, 2012 Author Share Posted February 21, 2012 It will not work, found out the hard way... ok just realized you had LE wheels not SE wheels. does anyone with the same 6 spoke wheels know if they will work? I found one other thread from a guy with an 03 SE 6 spoke and he says they wont work on his. Link to comment Share on other sites More sharing options...
seeraedave Posted February 22, 2012 Share Posted February 22, 2012 Anybody familiar with Rugged Ridge locking hubs? Link to comment Share on other sites More sharing options...
ArizonaPathy Posted February 23, 2012 Share Posted February 23, 2012 I have a 2003 SE with the same wheels, and the Warn hubs WILL NOT fit. You need a center bore in the wheel of 4", and the bore of those wheels is about 3.5". You need new wheels or to have the have the bore enlarged at a machine shop. Link to comment Share on other sites More sharing options...
arista5 Posted February 23, 2012 Author Share Posted February 23, 2012 I have a 2003 SE with the same wheels, and the Warn hubs WILL NOT fit. You need a center bore in the wheel of 4", and the bore of those wheels is about 3.5". You need new wheels or to have the have the bore enlarged at a machine shop. thank you!!!! Link to comment Share on other sites More sharing options...
jhwang799 Posted August 25, 2015 Share Posted August 25, 2015 anyone know if other locking hubs will fit? Sorry I'm new and been looking at this for sometime now Link to comment Share on other sites More sharing options...
totriz Posted August 25, 2015 Share Posted August 25, 2015 rugged ridge fits SE and LE wheels. you might need spacers for the SE wheels tough. check this thread: http://www.nissanpathfinders.net/forum/topic/33354-manual-locking-hubs-with-stock-03-04-wheels/ Link to comment Share on other sites More sharing options...
jhwang799 Posted August 25, 2015 Share Posted August 25, 2015 (edited) I saw that, i had the same rims as link u posted, but i dont feel good about messing with spacing. Has anyone able to install rugged ridge on them without spacers? If not i might have to buy that cheaper stock rims with larger hub covering. Edited August 25, 2015 by jhwang799 Link to comment Share on other sites More sharing options...
northbynorthwest Posted October 16, 2015 Share Posted October 16, 2015 For clarification: Warn hubs (p/n 29091) listed for Pathfinders up to 2001 will fit on a 2002 as long as the wheels have been replaced, but "don't fit" because the stock wheel center bore is too small? Also, are there any experiences with strength/reliability of Warn vs Rugged Ridge hubs? Link to comment Share on other sites More sharing options...
