Phantom01Pathfinder Posted January 5, 2012 Share Posted January 5, 2012 (edited) Ok, So i noticed today that my passenger rear bottom shock mount looks bent. But whats funny is that from the ground to the center of the bolt on both passenger and driver side bottom mounts it measures 8 3/8". Measured from flat concrete in my garage. Heres a pic of the rear Driver side to me the bottom of the mount looks level with the ground... Passenger side to me the mount looks bent... the bolt also is angled more towards the ground compared to the driver side. I know the pics are the greatest but does it look funny to you? I think the bolt looks bent in this last pic How can it look bent but the measurements are the same? and is that a good way to take a measurement?? Am I going crazy or can somebody confirm this for me with their 01+ Pathy...Cuz i do believe earlier generations have reverse shock mounts... thanks Keep the laughing to a minimum Edited January 5, 2012 by Phantom01Pathfinder Link to comment Share on other sites More sharing options...
01silvapathy Posted January 5, 2012 Share Posted January 5, 2012 Mines kinda the same, dont know why. Link to comment Share on other sites More sharing options...
Phantom01Pathfinder Posted January 5, 2012 Author Share Posted January 5, 2012 (edited) Mines kinda the same, dont know why. Is it possible that you could take a pic of your shock mounts when you get a chance? id like to see a good comparison... I know some ppl will think im crazy for checking this out...but this really questions me... Thanks Edited January 5, 2012 by Phantom01Pathfinder Link to comment Share on other sites More sharing options...
DanAK Posted January 5, 2012 Share Posted January 5, 2012 Is it possible that you could take a pic of your shock mounts when you get a chance? id like to see a good comparison... I know some ppl will think im crazy for checking this out...but this really questions me... Thanks Yep you are crazy I say unbolt and slide the shock off the mount and inspect for damage. If there are no cracks or really noticeable bends then I would get you a picture of mine but they have been cut and shortened so its not much of a comparison. Link to comment Share on other sites More sharing options...
edicer2 Posted January 5, 2012 Share Posted January 5, 2012 off topic but i think you might want to look into getting a drop down bracket for the panhard. Link to comment Share on other sites More sharing options...
snow4me Posted January 8, 2012 Share Posted January 8, 2012 Was under mine today and noticed the EXACT same thing, right side looked lower. Looks exactly like yours if it helps you sleep. Link to comment Share on other sites More sharing options...
nunya Posted January 8, 2012 Share Posted January 8, 2012 Since I like optical illusions I wanna see more of these "bent" r50 shock mounts! Link to comment Share on other sites More sharing options...
Phantom01Pathfinder Posted January 8, 2012 Author Share Posted January 8, 2012 (edited) Was under mine today and noticed the EXACT same thing, right side looked lower. Looks exactly like yours if it helps you sleep. Ok just looking for confirmation. Thanks. I just thought it was interesting that i noticed it now and not while installing shocks. Yah optical illusions are funny and sometimes bother me Ill try to get better pics soon... Edited January 8, 2012 by Phantom01Pathfinder Link to comment Share on other sites More sharing options...
Rick13 Posted January 9, 2012 Share Posted January 9, 2012 Looked at mine today. They are IDENTICAL to yours. Kind of funny. Link to comment Share on other sites More sharing options...
01silvapathy Posted January 9, 2012 Share Posted January 9, 2012 Its probably just the design of the mount, no need to worry about it as long as the shock still cycles without any issues. Link to comment Share on other sites More sharing options...
davo Posted May 18, 2012 Share Posted May 18, 2012 I just signed up after finding this on the web. I have exactly the same issue with RHS mount. Rubber bushes disintergrated on a trip requiring removal of shockers. When replacing bushes, I investigated and found:- THERE IS A LARGE HOLE manufactured IN THE SIDE OF THE MOUNT, WHEEL SIDE IT IS VERY HARD TO SEE A BUCKLE (BEND) CAN BE FELT IN THE SMALL AMOUNT OF METAL THAT IS LEFT. LHS IS MANUFACTURED THE SAME, BUT IS NOT BENT. Any thoughts, remedies Link to comment Share on other sites More sharing options...
davo Posted May 19, 2012 Share Posted May 19, 2012 Its probably just the design of the mount, no need to worry about it as long as the shock still cycles without any issues. Very true, I think my rubber issue was due to no crush tubes being fitted when lift kit was installed by local garage. And Phantom your not crazy or seeing illusions, The actual frame for the mount is bent, the bolt(pin) is perfectly ok. Nissan saved two ounces of weight to cause this. You would probably have to remove the brake drum backing plate to get a photo. Hope this helps. Link to comment Share on other sites More sharing options...
Phantom01Pathfinder Posted May 19, 2012 Author Share Posted May 19, 2012 Very true, I think my rubber issue was due to no crush tubes being fitted when lift kit was installed by local garage. And Phantom your not crazy or seeing illusions, The actual frame for the mount is bent, the bolt(pin) is perfectly ok. Nissan saved two ounces of weight to cause this. You would probably have to remove the brake drum backing plate to get a photo. Hope this helps. thanks davo...its been a while since ive looked under my truck to figure this out, but good to know others are designed the same way. got to deal with a EVAP leak...hmmm Link to comment Share on other sites More sharing options...
devonianwalk Posted May 19, 2012 Share Posted May 19, 2012 ...got to deal with a EVAP leak...hmmm Misery loves company. Link to comment Share on other sites More sharing options...
Alkorahil Posted May 19, 2012 Share Posted May 19, 2012 I think this is how it is made..... Link to comment Share on other sites More sharing options...
davo Posted May 20, 2012 Share Posted May 20, 2012 I think this is how it is made..... The RHS BENT ONLY and the shocker doesn't line up when top mount is unbolted, Unlikly but I'm open to all input. Has anybody NOT put heavy duty shocks on the back and remained with the originals, I'm guessing these will be OK. Link to comment Share on other sites More sharing options...
Tungsten Posted May 28, 2012 Share Posted May 28, 2012 This looks like a normal thing for R50s. One I was under had the right mount just like this too. Link to comment Share on other sites More sharing options...
