Slartibartfast Posted August 7, 2011 Share Posted August 7, 2011 Okay, so, there are two wires coming out (looks like, didn't trace with my hand) of the trans. They go into the top of this grey plug, and apparently three wires are supposed to come out of the bottom, one black and two white. (It's up against the fuel/brake/etc lines on the passenger's side frame rail, but the multitude of zip ties suggest that it wasn't meant to go there.) As you can see, the black one is busted off. (I'm assuming that one of the lugs was originally empty?) In an attempt to figure out what it was, I followed the bundle into the engine bay, past this plug, and a wad of electrical tape (previous owner?), into the main harness going through the passenger's side of the firewall. It doesn't seem to be driving funny, shifting funny, etc. I haven't tried pulling codes yet. I do plan to repair this (is there a right way to do this?), but I'd kinda like to know what I'm looking at. Thanks in advance. Link to comment Share on other sites More sharing options...
adamzan Posted August 7, 2011 Share Posted August 7, 2011 It looks like someone put a universal o2 sensor into your truck. I hate those things. Link to comment Share on other sites More sharing options...
Tungsten Posted August 7, 2011 Share Posted August 7, 2011 x2 on the universal o2 sensor Link to comment Share on other sites More sharing options...
Towncivilian Posted August 7, 2011 Share Posted August 7, 2011 Wow, your engine bay is clean! ... sorry for being useless. Link to comment Share on other sites More sharing options...
sewebster Posted August 7, 2011 Share Posted August 7, 2011 Yeah, follow the wires the other direction to the o2 sensor on the exhaust? Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 7, 2011 Author Share Posted August 7, 2011 Thanks guys. Adamzan, what's wrong with them? Apart from the wiring, I mean. Towncivilian, it's amazing what a pressure washer can do. Previous owner had every cranny on this thing full of pine needles... Link to comment Share on other sites More sharing options...
adamzan Posted August 7, 2011 Share Posted August 7, 2011 My friend put one on his truck and he found that moisture kept getting into the connection and corroding it. Then again I live in Canada so maybe our climate is what ruins them. Link to comment Share on other sites More sharing options...
silverton Posted August 8, 2011 Share Posted August 8, 2011 I like how you (previous owner?) has most everything labeled. Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 9, 2011 Author Share Posted August 9, 2011 Oxygen sensor it is... wires went right over the trans to a lug on the exhaust. Given the attention to detail of the guy who re-did my exhaust, the plug thing was probably his work. I figured I'd just solder it up, but the wire from the harness wouldn't take solder. I couldn't cut it, either, it just slid between the blades. I'm not sure just what it's made of, definitely not copper though. Anyway, I reused the little screw connectors I found inside what I'd thought was a plug, and the connections feel solid. I'll run the codes tonight or tomorrow to make sure I did it right, and then glob some grease over the ends to keep water etc out. Thanks guys! And Silverton, yeah, I found a Sharpie. That, and I've seen way too many bad sci-fi movies; I don't want to be the guy opening the hood, seeing steam, and saying "the engine is broken." Link to comment Share on other sites More sharing options...
sewebster Posted August 9, 2011 Share Posted August 9, 2011 I think our O2 sensors only have two wires? So quite possibly you don't need that other wire connected. Hopefully you have the correct two wires connected at least Check at the connector you found in the engine bay? How many wires does it have? This thread makes me glad I bought the "custom fit" O2 sensor Link to comment Share on other sites More sharing options...
adamzan Posted August 9, 2011 Share Posted August 9, 2011 They have 3 wires. Link to comment Share on other sites More sharing options...
silverton Posted August 9, 2011 Share Posted August 9, 2011 And Silverton, yeah, I found a Sharpie. That, and I've seen way too many bad sci-fi movies; I don't want to be the guy opening the hood, seeing steam, and saying "the engine is broken." That kinda makes me wanna see a pic of the rest of your engine bay! Link to comment Share on other sites More sharing options...
Slartibartfast Posted August 16, 2011 Author Share Posted August 16, 2011 LOL not much to see, only other thing I labelled is the AC circuit (compressor and filler). I'll label more as I figure out what it does/run out of real things to fix. The only other notable thing under the hood is where my friends and I spray painted Bill Murray's head. I printed off the "how to read computer codes" today, so I'll check the computer tomorrow and make sure my hack wiring job is working. I did squirt some dielectric grease into the connections to keep them clean and dry, and wrapped it up in electrical tape. Now it blends in with the rest of the wiring. (And yes, the connector in the engine bay is three-wire.) Link to comment Share on other sites More sharing options...
