Reshma Posted May 4, 2011 Share Posted May 4, 2011 (edited) My front driver side of the van TRUCK squeaks....no matter what. The slightest movement up and down causes it to squeak. any ideas? Edited May 4, 2011 by PathfinderIII Link to comment Share on other sites More sharing options...
adamzan Posted May 4, 2011 Share Posted May 4, 2011 Check your tension rod bushings, mine squeaked. Also check the ball joints maybe they need some grease. Link to comment Share on other sites More sharing options...
Reshma Posted May 4, 2011 Author Share Posted May 4, 2011 Interesting...if i knew what either of those looked like. XD ima noob. please understand im learning. Link to comment Share on other sites More sharing options...
Kyle94 Posted May 4, 2011 Share Posted May 4, 2011 (edited) one: its not a van two: my dads ford does that all the time, come to the conclusion its the ball joints. Edited May 4, 2011 by Kyle94 Link to comment Share on other sites More sharing options...
nunya Posted May 4, 2011 Share Posted May 4, 2011 lube (greese) your front end good, if it even has zerks fittings, make sure your shock is tight, check the tension rod bushings (look at the back side of the lower control arms, the bushings that go through the frame) Link to comment Share on other sites More sharing options...
k9sar Posted May 4, 2011 Share Posted May 4, 2011 it's a pathy... it squeeks Link to comment Share on other sites More sharing options...
Kyle94 Posted May 4, 2011 Share Posted May 4, 2011 it's a pathy... it squeeks mine dont.... Link to comment Share on other sites More sharing options...
adamzan Posted May 4, 2011 Share Posted May 4, 2011 These are the tension rod bushings: If they are not sitting in the little bushing cups or move a lot when you bounce the truck I would replaced them. They squeaked real bad on mine every time I got in or out of the truck, or hit any little crack or bump when I was going slow enough to hear it. Link to comment Share on other sites More sharing options...
