Straight piping my WD21
Tungsten
Here's the story...
My midpipe, one with the o2 bunghole, has gone to crap and now looks like swiss cheese.
I have the Doug Thorley headers with a 2.25" collector output.
I want to know three things:
1. What is the thread pitch of the o2 bung or what would be a good screw in thingy into a custom pipe?
2. Is it possible to buy a test pipe to make a straight pipe from the collector to the catalytic converter?
3. Is there an already made 2.25" test pipe that will fit the stock oxygen sensor?
I'm asking this because I can't find anyone around here that will make me a stainless steel pipe with flanges and an o2 bung.
EDIT 1: The pipe has to be ~26 inches long.
EDIT 2: Something like this but longer so it clears the transfer case (but it might work, need additional measuring): http://www.genkituning.com/1993-1997-Nissan-Altima-Test-Pipe-Converter-p/1-excs-na93.htm
EDIT 3: Some photos for reference and proof that a straight test pipe can work (I might have a few more photos later):
Edited by Tungsten
  • Replies 69
  • Created
  • Last Reply
Top Posters In This Topic
Can you not just order some pipe / flanges off the net and have a shop bend and weld and assemble?
It turns out that with my setup there is not even a need to bend. I just need flanges and a stainless steel pipe. I have no idea how much welding I can get done around here, no one seems to want to touch stainless steel and the test pipe already has the flanges professionally welded on. The only thing I'm not sure of right now is which o2 bung to screw in there.
Edited by Tungsten
Damn, you are lucky my buddy just bought a WD21 and needed some parts, I found it first try.
Where are one of my 10 calipers??
Where is the thread gauge??
*grumble*
It's a short thread, but I'm sure it is an M18x1.5.
some more pics of currently routed exhaust, you can see how the cat needs a slight angle or may be too far from the midpipe
Edited by Tungsten
You need calipers...
I have them, I like my ruler more. :tongue:
From the looks of this, I need to get a 2.50" pipe put together with 2.50" flanges.
Also, the O2 bung is M12x1.5 and NOT M18x1.5 as I was told.
M12x1.5 bung on the left vs the M18x1.5 bung on the right
Looks like I will be sending EVERYTHING back! :/
I truly apologize, the O2 sensor for my 95 is M18x1.5. I did not think to check that they changed the thread size between the years. Did you check or specify??
Picture of a 91 O2 sensor.
http://www.rockauto.com/catalog/moreinfo.php?pk=481678
Picture of a 95 O2 sensor
http://www.rockauto.com/catalog/moreinfo.php?pk=481588
Hard to tell and pictures aren't always accurate, but different part numbers...
I checked and got different answers on the sizes. So I decided to get a M18 and see if that fits.
I believe that the late models like 94-95 have different sensors because that's when the ECU has changed.
It's not a big deal just a little annoying to have to order another bung.
BTW, you USE a 17mm wrench to extract the M12x1.5 sensor. So there's one bonus of having the smaller sensor, no need to have a special oxygen sensor wrench. Although using a bigger wrench to extract these is much better than having to use a smaller one.
Edited by Tungsten
All the "special wrench" is, is a socket with the side cut out for the wires to go through. It doesn't make a difference what size the 02 is the socket makes it easier than using a wrench...
Also, if you're extracting a dead sensor you can just cut the connector off the end and put a regular (long) socket on (thread the wires through).
EDIT: sorry, that makes no sense, what I think I meant to say is you can thread the wires through the closed end of a wrench. If you cut the wires entirely off then you might get a long socket on it.
Edited by sewebster
I believe the 22MM oxygen sensor is the Titania type, and the 17MM is Zirconium. Nissan has been switching sizes/types around since they first made the Z31 depending on the year and engine type. There's really no rhyme or reason to it. I do know that each computer is designed to run a certain type of sensor, and mixing them around can cause some damage. The sensor on my '88 is 17MM.
OH HELL YES, first section made!!!!
Hey, it's almost straight... :lol:
I guess this should be renamed to custom "home-made" 2.5" exhaust building thread.
