SRN Posted March 20, 2011 Share Posted March 20, 2011 I'm interested in getting a front Limited Slip to complement the rear. I have searched here as well as other sites and not found much. I have found two interesting bits of information that I was hoping could be extrapolated on. First, apparently in Australia WD21's had a front LSD option. Has anyone tried to bring one of these diffs into the states? Second, I read that someone got an ARB designed for the rear diff in a KA24 powered D21 working in the front of a VG30 powered WD21. Does this suggest that an OEM LSD from such a truck might be able to work as well? Finally, after market options. I don't see any, am I missing one somewhere? Link to comment Share on other sites More sharing options...
Kingman Posted March 20, 2011 Share Posted March 20, 2011 Z31 300ZX R200 limited slip rear end drops right into the carrer. Link to comment Share on other sites More sharing options...
MY1PATH Posted March 20, 2011 Share Posted March 20, 2011 there is also the Nismo LSD for the front of Fontiers and X's. Calmini and 4x4parts.com sell em too. Breakaway settings vary from year to year. The most the clutch based 300zx were about 80ft lbs The Nismo units were a measly 60 and the other 2 still can't tell me what the breakaway is on their product. For reference the stock wd21 rear is 280 1 Link to comment Share on other sites More sharing options...
madhornet Posted March 20, 2011 Share Posted March 20, 2011 i bought mine from 4x4.com and luv it but its abitch to steer especially if u wanna daily drive it in the winter Link to comment Share on other sites More sharing options...
94pathfinder Posted March 20, 2011 Share Posted March 20, 2011 honestly, when my ifs was still on i had the stock open, welded, and an ARB. save the money and get the ARB, trust me. you will love it, just don't drive stupid with it. Link to comment Share on other sites More sharing options...
Kingman Posted March 20, 2011 Share Posted March 20, 2011 Good thing about LSD is it's progressive as it engages, so it's predictable and easy to control. Just don't put a ratcheting locker in the front, it'll yank the wheel right out of your hands and more than likely stuff you into a tree or bank...or off a cliff. Link to comment Share on other sites More sharing options...
aranay Posted March 20, 2011 Share Posted March 20, 2011 I had always wondered about what I refer to as a momentary locker which would be either electrically controlled or something as simple as a camble activated locker for my front diff. I just basically want something for the odd time when I want to crawl over a log or go up an exceptionally greasy bank/ditch Link to comment Share on other sites More sharing options...
MY1PATH Posted March 21, 2011 Share Posted March 21, 2011 i bought mine from 4x4.com and luv it but its abitch to steer especially if u wanna daily drive it in the winter Try locking only one wheel (3 wheel drive) in the winter streets. It will help you combat the under steer issues and still provide you some pull from up front Link to comment Share on other sites More sharing options...
Tungsten Posted March 21, 2011 Share Posted March 21, 2011 I say forget front limited slip, those CVs will take a beating with that. Link to comment Share on other sites More sharing options...
Kingman Posted March 21, 2011 Share Posted March 21, 2011 I say forget front limited slip, those CVs will take a beating with that. Bull@!*%. Link to comment Share on other sites More sharing options...
MY1PATH Posted March 21, 2011 Share Posted March 21, 2011 I say forget front limited slip, those CVs will take a beating with that. Go wheelin first and then tell us what you think. lol Link to comment Share on other sites More sharing options...
KovemaN Posted March 21, 2011 Share Posted March 21, 2011 I just installed a front LSD in my Pathfinder and I wheeled the piss out of it last week. Everything worked great and no CV breakage. It probably helped that I also installed drop bushings in the diff before I put it back in. I was able to climb everything with no slippage and I didn't really notice a huge difference in the steering response. LSD FTW! Link to comment Share on other sites More sharing options...
Kingman Posted March 22, 2011 Share Posted March 22, 2011 Yeah, you won't break a CV axle from a LSD. You'll break one from a locker though. Link to comment Share on other sites More sharing options...
SRN Posted March 23, 2011 Author Share Posted March 23, 2011 So my understanding is that the 300ZX one is the "best" due to its breakaway point. But would the lower breakaway be better with winter street driving? My Pathy will see quite a bit of dirt, but probably not much terribly difficult terrain. I'm currently sourcing a factory rear LSD and my thought was having one up front would help offset the fact that I wouldn't have a full locker in the rear. Perhaps I'm over stressing it because I've had a locker in the rear of my Samurai for the last 12 years and have a hard time imagining going anywhere without one. Link to comment Share on other sites More sharing options...
MY1PATH Posted March 23, 2011 Share Posted March 23, 2011 Like I said before for winter street driving with LSD you should only lock 1 hub This will eliminate the understeer issues you get with locking both and still provide you some power from the front. Search my threads for modifying the rear LSD for more grip. Or get a powertrax for your open. I think they run about 300 bucks. Any LSD up front will be better than open. The 300zx model is hard to find as most of them were open or viscous type. Link to comment Share on other sites More sharing options...
Kingman Posted March 23, 2011 Share Posted March 23, 2011 No, 300ZX clutch LSD is the easiest to find. The were put in from 4/87-'89 - standard on all turbo cars and optional on the NAs. Only '88 Shiro Special editions, which they made 1002 of, had the viscous LSD and it is a heaping pile of garbage. '84-3/87s were all open differentials. The problem is the price point, 300ZX CLSD differentials are expensive when the seller knows what it is and it's value. A unit in good shape can run upwards of $1,000. Link to comment Share on other sites More sharing options...
enkrypt3d Posted March 30, 2013 Share Posted March 30, 2013 will the Z31 300ZX R200 limited slip rear end fit on my 95 front diff? Link to comment Share on other sites More sharing options...
Kingman Posted April 3, 2013 Share Posted April 3, 2013 No. Link to comment Share on other sites More sharing options...
enkrypt3d Posted April 3, 2013 Share Posted April 3, 2013 uh ............ ok? So what will fit?? Its obviously something that would be helpful no? Link to comment Share on other sites More sharing options...
Kingman Posted April 3, 2013 Share Posted April 3, 2013 I read your post entirely wrong, I thought it had read will an R200 LSD fit the rear (H223b). I was so blunt because that was a very dumb question. My bad man. Yes of course it will, its an R200. The LSD unit goes inside the Pathfinder housing. Link to comment Share on other sites More sharing options...
enkrypt3d Posted April 3, 2013 Share Posted April 3, 2013 np - the trick is to #1 find one #2, find one thats not toast and #3 thats the right model... from what i get I dont want the VLSD we want the CLSD? Link to comment Share on other sites More sharing options...
Nefarious Posted April 4, 2013 Share Posted April 4, 2013 yup CLSD found in 87-89 turbo models and some NAs were equipped. aluminum finned diff cover gives it away. just started to thread to see if there were any OTHER options ie: C200 LSD etc Link to comment Share on other sites More sharing options...
enkrypt3d Posted April 4, 2013 Share Posted April 4, 2013 so if I got one out of a junk yard im sure it'd most likely be toast requiring rebuild right? Link to comment Share on other sites More sharing options...
Kingman Posted April 4, 2013 Share Posted April 4, 2013 Not that likely, they're extremely strong but, abuse is abuse... It would be a good idea to pull it apart and look though, just make sure you follow the book to the T otherwise you will ruin it. Link to comment Share on other sites More sharing options...
enkrypt3d Posted April 14, 2013 Share Posted April 14, 2013 Yea I would never attempt rebuilding an LSD by myself.. that's way above my head when it comes to transmissions or gears. Link to comment Share on other sites More sharing options...
