grill and hood
shotzie417
Been covered a fiew times... Hoods are a 4 bolt swap, 0 skill needed besides "righty tighty-lefty loosy" and a second set of hands helps for holding porposes, grill mounts effortless but you will either need to modify the shell to fit around the wd21 headlights as MY1PATH did or do a complete HB headligh swap as I have. Cosmetically the HB markers are different looking but either set will work
i was gathering pieces for this transformation until my modification agenda was thrown off course
Me too. There's actually a couple companies that offer cowl hoods for the HB. I've not seen one on a Pathy yet, but I'd sure like to.
The HB headlight swap is easy. Just pull the buckets and bulb connections from a junkyard donor. It's a bolt-on / wire nut affair.
i know the bumper on nunyas truck is HB bumper have had several of those on my old hbs back in the day and grim gregs looks like square tubeing fabbed up to wrap around the front
