Shocks ?
jwmyers23
I have a 95 4 door path with a 2" body lift, the t-bars are cranked and has jgc springs. I have figured out that disconnecting the rear sway bar gets you more flex but I think I'm being limited by the oem shocks. This may sound like a dumb question, but would longer shocks offer more flex? If so what would be a good size shock? Also what is a good brand that doesn't cost an arm and a leg and is a direct fit?
If you flex too much on the stock springs, they will fall out, just fyi. Find someway to secure them, ie zip ties!
Very good point! Its about what? 5 or 6 inches of flex to have them fall out?
