Shocks
Islandpath
Replacing the rear shocks is really easy, just unbolt the old ones and bolt the new ones in. Basically the same with the front, except the stock system uses a vertical stud on the top, and some aftermarket shocks don't have that.
Edited by sewebster
I still have my old set of Pro Comp ES3000s laying around if you're interested, stock length. They're comparable ride and quality-wise to Rancho RS5000s. A new set of the PCs are about $140, the Ranchos are $190. I'll clean 'em up and inspect them if you're interested, $50-$60 or so. I'll even throw in some new red boots. Snazzy!
Depending what you want to do with the truck. If you plan on lifting/wheeling I would get some rancho, pro comp or bilstein shocks in extended length. If you just want stock replacements for the street the KYB gr-2 is a good choice. The Monroe sensatrac is ok but if you go off road or tow much they won't last long.
