Eyehategod310 Posted June 3, 2010 Share Posted June 3, 2010 (edited) whenever i hit a pot hole or a speed bump too hard the rear door light turns on and off. it happens a lot then doesnt happen for like a week. would this be an electrical problem or a problem with the door latch? Edited June 3, 2010 by Eyehategod310 Link to comment Share on other sites More sharing options...
nunya Posted June 3, 2010 Share Posted June 3, 2010 Somewhere I belive there is a thread about cleaning the contacts or something with the switch. Been a while since I seen it and I ain't in a searching mood... Link to comment Share on other sites More sharing options...
adamzan Posted June 3, 2010 Share Posted June 3, 2010 You need to space out the striker plate with a couple washers under it. 1 Link to comment Share on other sites More sharing options...
Eyehategod310 Posted June 3, 2010 Author Share Posted June 3, 2010 You need to space out the striker plate with a couple washers under it. so just unscrew then screw it back on with washers under it? Link to comment Share on other sites More sharing options...
adamzan Posted June 3, 2010 Share Posted June 3, 2010 so just unscrew then screw it back on with washers under it? Yep. Worked for me. Link to comment Share on other sites More sharing options...
Eyehategod310 Posted June 4, 2010 Author Share Posted June 4, 2010 (edited) Yep. Worked for me. i'll get some washers and let you know if it stops. Edited June 4, 2010 by Eyehategod310 Link to comment Share on other sites More sharing options...
Nismojunky Posted June 4, 2010 Share Posted June 4, 2010 worked for me to Link to comment Share on other sites More sharing options...
silverton Posted June 4, 2010 Share Posted June 4, 2010 You have a rear door light? My hatch just lights up the door ajar light. drove me nuts one day when I noticed it was on, opened all four doors and shut them, with no change on the light. Figured the hatch would have its own like like the tire carrier. Link to comment Share on other sites More sharing options...
