wilson Posted April 15, 2010 Share Posted April 15, 2010 (edited) howdy after having lifted my front end, I find that the ride is too stiff for my liking on anything but pavement. I think that I cranked them a little too much causing very little down travel. but still the ride is not great after backing them off a bit. do you think that aftermarket bars(stiffer), utilizing less preload, will improve this? if so which do you prefer? I've only seen calmini and SAW. any others? Edited April 15, 2010 by wilson Link to comment Share on other sites More sharing options...
GrimGreg Posted April 15, 2010 Share Posted April 15, 2010 You named the only 2 companies that make "stiffer" T-bars. You said you backed them off, how much? General rule is to leave at least 1/2" gap between the upper bump stop and the upper control arm. How are your shocks? Did you replace them when you cranked? If they are shot, then they won't soak up any of the bumps, and it is just your tires and bump stops for cushioning. Link to comment Share on other sites More sharing options...
wilson Posted April 16, 2010 Author Share Posted April 16, 2010 You named the only 2 companies that make "stiffer" T-bars. You said you backed them off, how much? General rule is to leave at least 1/2" gap between the upper bump stop and the upper control arm. How are your shocks? Did you replace them when you cranked? If they are shot, then they won't soak up any of the bumps, and it is just your tires and bump stops for cushioning. yeah, I probably got about 3/8" clearance in between the bump stop and UCA. I'll back that off a bit more. brand new shocks where put in with the UCAs. I'm still not sure that 1/8" isnt gonna soften up the ride enough for me. Link to comment Share on other sites More sharing options...
DavefromOZ Posted April 16, 2010 Share Posted April 16, 2010 (edited) Tough dog here in Oz do T-bars for the Pathy, but I would think they would be more expensive being from here. Use the link below to see what they offer. Clicky Or there are some Ironman ones on Ebay here in Oz Another clicky Edited April 16, 2010 by DavefromOZ Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 18, 2010 Share Posted April 18, 2010 does any company make the 2 stage torsion bars anymore? I had them in my 87 hardbody from Jim Connor Racing? Link to comment Share on other sites More sharing options...
SteeevO Posted April 19, 2010 Share Posted April 19, 2010 not that i know of. If someone is still making them please let me know. Link to comment Share on other sites More sharing options...
ahardb0dy Posted April 19, 2010 Share Posted April 19, 2010 was looking thru an old Jim Conner racing catalog that I have last night and it says they are the only one's that make the 2 stage bars for Nissan, I thought sway a way was making all their bars but not sure as sway a way doesn't list a 2 stage bar on their site either. I know someone was selling them for toyota's maybe it was Downey but there bars used a metal sleeve that ran part way up the bar to engage the second stage, unlike the way the Nissan 2 stage bars were set up. man I had so many cool parts on my Hardbody when I traded it in, should have took them off before I traded it in!! If I had only known I would have another Nissan truck later on down the road!!! Link to comment Share on other sites More sharing options...
tmoore4512 Posted May 11, 2010 Share Posted May 11, 2010 ahardbody, I think we have all been there brother...life goes on...and someone else is enjoying the fruit of your labor... Link to comment Share on other sites More sharing options...
tmoore4512 Posted May 20, 2010 Share Posted May 20, 2010 Think its time to re index mine...the front is sagging like crazy... Link to comment Share on other sites More sharing options...
