Jmax5000 Posted March 8, 2010 Share Posted March 8, 2010 Hey guys it's been awile since ive been here, But i havent had too many issues with the truck in some time. But that has changed. Just the other day the taillights on my pathy decided they didnt want to come on any more. The brake lights still fire up, but no tail lights when the switch is on. Is this just a fuse issue, or do i have to start digging through the wiring to fix?? Link to comment Share on other sites More sharing options...
EarlFairweather Posted March 8, 2010 Share Posted March 8, 2010 What have you checked so far? Start with your fuses, Then bulbs, if you need to pull out the wires by the lights. Turn the switch on and check with a voltage tester to see if they are getting power that far back. Link to comment Share on other sites More sharing options...
OldSlowReliable Posted March 8, 2010 Share Posted March 8, 2010 check out the wiring to them in the 1/4 panel, perhaps a wire de-soldered from the socket and is causing it to not light when power is being sent to it. If your problem is what I think it is, chances are its either the fuse or that, MAYBE even perhaps the filament for that brightness isn't working... Link to comment Share on other sites More sharing options...
PATHRIDER Posted March 9, 2010 Share Posted March 9, 2010 If your turn signal indicator is flashing real fast its gotta be the bulb Link to comment Share on other sites More sharing options...
silverton Posted March 9, 2010 Share Posted March 9, 2010 the blinker and tail/stop lights are different bulbs. Link to comment Share on other sites More sharing options...
PATHRIDER Posted March 9, 2010 Share Posted March 9, 2010 the blinker and tail/stop lights are different bulbs. I know that but when one of your tail lights is out may it be stop / park / turn signal lights your turn signal indicator flashes fast..The left and right arrow on your dashboard Link to comment Share on other sites More sharing options...
GrimGreg Posted March 9, 2010 Share Posted March 9, 2010 2 flashlights ducktaped to the sides of the truck facing to the rear with some red perminant marker over the lens ought to fix you right up! Link to comment Share on other sites More sharing options...
Jmax5000 Posted March 9, 2010 Author Share Posted March 9, 2010 Well its been really cold here the last couple of days.. so i havent been able to take a look at it yet, but the fuses are ok.. (at a glance). the wierd thing is that the stop lights work (same bulb). But i will get in there with a volt meter hopefully today or tmrw and update. Thanks for the input everyone! Link to comment Share on other sites More sharing options...
