TerranoNZ Posted December 19, 2009 Share Posted December 19, 2009 I noticed that on 2 VG30's that have had broken exhaust studs that the answer is "3" Just wanted to see if there was any pattern.... Might be a hot spot of the head or something Link to comment Share on other sites More sharing options...
adamzan Posted December 19, 2009 Share Posted December 19, 2009 (edited) Right hand closest to the firewall. But I will note that the passenger side ones were stripped on the threads that the nuts that hold the manifolds go. Edited December 19, 2009 by adamzan Link to comment Share on other sites More sharing options...
MY1PATH Posted December 19, 2009 Share Posted December 19, 2009 rh by the firewall, rh center, Lh by radiator & Lh center.(iirc) and somehow it did not tick or make any leaking noises even with 2 of the broken studs just sitting in the heat sheild. Link to comment Share on other sites More sharing options...
Precise1 Posted December 20, 2009 Share Posted December 20, 2009 None... Ever... What is your issue?? I recall Derek guessing the end studs one time so there is probably is a trend, but I'll be damned if I know what it is... B Link to comment Share on other sites More sharing options...
BoneZ Posted December 28, 2009 Share Posted December 28, 2009 I knew i had a exhaust leak at the manifolds but when i went looking found that both sides only had the center 2 studs left the rest were broke. Needless to saw i pulled them all and replaced them with a better product along with the gaskets. Link to comment Share on other sites More sharing options...
edicer2 Posted December 28, 2009 Share Posted December 28, 2009 on both of my pathys and on my friends it was the rear right ones by the firewall Link to comment Share on other sites More sharing options...
SamTex Posted January 5, 2010 Share Posted January 5, 2010 (edited) I had a total of three broken studs, luckily only one was sheered off completely(driver side closest to radiator), the others had enough left on them for vice grips to do the trick(driver and pass side closest to firewall). Edited January 5, 2010 by SamTex Link to comment Share on other sites More sharing options...
5523Pathfinder Posted January 9, 2010 Share Posted January 9, 2010 None... Ever... What is your issue?? I recall Derek guessing the end studs one time so there is probably is a trend, but I'll be damned if I know what it is... B Yep, typically both the outers snap. The problem is that one typically doesnt snap until ou try and take it off. Fun times. Link to comment Share on other sites More sharing options...
