ARB Bumper
ebag17
My pathfinder was in a slight front in collision. My question is for someone who has the arb bumper and i would like to know how it attaches. Does it use those two factory brackets that stick out to hold the original bumper on? Thanks for your time.
-G
Mine is not mounted the original way the upper mounts was designed but iirc you completely remove the stock bumper brackets and the ARB bolts to the frame where the brackets did. But the primary mounting point is at the fram using the two mounting holes (per side) where the factory tow hook is.
Just a quick question re where it mounts where the old bumper iron were, does it use the same bolt pattern and both bolts on both sides?
I'm asking because I am in the process of fabbing a new tubular winch bar and want to use this same mounting setup. Thanks.
No, it only uses the upper frame mount. Here you can see the mounts (just before I chopped em :D ):
