Simon Posted September 24, 2009 Share Posted September 24, 2009 I have personally seen 2 transmissions completely FAIL shortly after putting GL-5 fluid in them. 1 in a pathfinder, 1 in a 350z One of those people took the shop that put the gl-5 fluid in their transmission to court and won a settlement. They had 3 samples of fluid sent to a lab for testing, and he shared the results with me. 1 test was brand new never used gl-4 fluid 1 test was brand new never used gl-5 fluid 1 test was the fluid from his transmission. There was a huge difference in the additives between the gl4 and 5, specifically with the additives that control friction (from what I remember from reading the report) bottom line, don't use gl-5 fluid in your transmission. Although you might get lucky, and use a brand that is soft metal safe, you could just as easially not. Happened with an Xterra as well, and the owner got a partial settlement. You might know of that one as well Mike. Link to comment Share on other sites More sharing options...
Terrano1992 Posted September 24, 2009 Share Posted September 24, 2009 Mobil 1® Synthetic Gear Lube LS 75W-90 "LS" suffix means "Limited Slip" additive. I think this oil is supposed for use in limited slip differentials, not in manual gearboxes. Another Mobil1 example: Mobilube SHC (synthetic 75W-90 for all GL-4 and GL-5 applications) and Mobilube SHC LS (synthetic with "Limited Slip" additive, 75W-90 GL-5, for limited slip diffs). Link to comment Share on other sites More sharing options...
ticker Posted September 24, 2009 Author Share Posted September 24, 2009 You can't find any between; Car Quest, NAPA, Auto Zone, .... We have like 10 different automotive chains in town, lol. Haven't found it yet. Just went to 3 stores, 2 advanced and one Auto Zone. Each had exactly the same products although one had no 75w-90 at all. The others had Valvoline which is a GL-5 oil, and they both had Coastal which is compatible with GL-3,Gl-4,GL-5 which freaks me out as most things that are intended for broad apllications do none particularly well. One interesting note. Advanced was selling the Royal Purple 75w-90 for $19.99 while two blocks away Auto Zone was selling it for $14.99! What a rip off. Strange that it seems like there are an awful lot of vehicle s that require a fluid that is so hard to find. I'm going to call a few other places and see if I can't track some down. ( Link to comment Share on other sites More sharing options...
ticker Posted September 24, 2009 Author Share Posted September 24, 2009 So after 2 Advanced Auto's and Auto Zone I went to NAPA, Car Quest, PepBoys, O'reilly, another NAPA, Wal-Mart, and a Nissan Dealer. I found 1 product that was API GL-4 made by sta-lube from the NAPA which is so close to my house I could walk there. The only thing was it is 85w-90 not 75w-90. This is what I'm going with. Most every one I spoke to at the autoparts stores said that GL-5 supersedes GL-4 which from everything I have learned is not correct. This seems like a pretty messed up situation for someone wanting to put the correct oil in their ride. Thanks for all the advice and help. BTW the Nissan dealer uses a GL-5 Castrol Syntec at $17.99 a quart, no thanks my ass already hurts from driving to 10 different stores. Link to comment Share on other sites More sharing options...
Precise1 Posted September 25, 2009 Share Posted September 25, 2009 The only thing was it is 85w-90 not 75w-90 Now that you mention it, I'm pretty sure that is what I wound up using also as it was all that I could find... A little stiff shifting in first and second when it was cold, but 5 minutes/1 mile and no issue. Most every one I spoke to at the autoparts stores said that GL-5 supersedes GL-4 which from everything I have learned is not correct. Yep. Everyone I talked to insisted that GL-5 was what I needed!! I finally asked one guy if that is what he ran in his pathfinder manual transmission. "I don't have a pathfinder" was the reply so I told him to quit wasting me time... $17.99 a quart, no thanks my ass already hurts LOL B Link to comment Share on other sites More sharing options...
morpheus Posted September 25, 2009 Share Posted September 25, 2009 (edited) Happened with an Xterra as well, and the owner got a partial settlement. You might know of that one as well Mike. It was an xterra then, not a pathfinder my mistake... yes, I know about that, but I wasn't involved with it... it was done somewhere else. Edited September 25, 2009 by morpheus Link to comment Share on other sites More sharing options...
Simon Posted September 25, 2009 Share Posted September 25, 2009 It was an xterra then, not a pathfinder my mistake... yes, I know about that, but I wasn't involved with it... it was done somewhere else. Oh, I know you weren't involved, buddy. Just a bad situation, that one. It got real ugly in a couple of places. Link to comment Share on other sites More sharing options...
adamzan Posted September 25, 2009 Share Posted September 25, 2009 I was looking at the reciepts I have for the r50 and when we had all of the fluids changed, I was relieved to see "X amount of liters of GL-4 75w90" This was at a Pennzoil place. Link to comment Share on other sites More sharing options...
ticker Posted September 29, 2009 Author Share Posted September 29, 2009 So its been a few days since I put the Sta-Lube 85w-90 GL-4 in the transfer case. (Manual calls for the impossible to find 75w-90 GL-4) As I was forewarned when cold shifting into 1st and 2nd is a bit stiff. I not really thrilled with. I also heard a bit of a wine for the 1st half mile or so this morning. It was cold(relatively) lat night, about 50 F and I'm concerned what is going to happen when it gets to be 10 F outside. I found out that JEG'S, which is right down the road sells REDLINE MT-90 which I've heard good things about. Anyone running this in their R50? Link to comment Share on other sites More sharing options...
