180sx Posted February 5, 2010 Share Posted February 5, 2010 Just lift the motor a bit. Probably easier if you take off the transmisson mount to angle it more. Link to comment Share on other sites More sharing options...
new4x4r Posted February 5, 2010 Share Posted February 5, 2010 I'll see what Ican do.. If you guys hear some really loud Cussin', its just me removing the blocks again hahaa Link to comment Share on other sites More sharing options...
shift220 Posted February 5, 2010 Author Share Posted February 5, 2010 Just lower the front diff? Goodluck and remember to post up some pics! Link to comment Share on other sites More sharing options...
shift220 Posted February 6, 2010 Author Share Posted February 6, 2010 Oh wait you have to slip that block in as well. Yup, carefully raise the engine. You could also loosen the bolts to the blocks and let it hang a little depending on how long your bolts are. Link to comment Share on other sites More sharing options...
new4x4r Posted February 8, 2010 Share Posted February 8, 2010 Ok so I raised the motor nice and slow, installed the last effin spacer block. Now I'm looking at doing my steering extension. I laid on the floor for a good 45 mins weighing the Pros and Cons of turning the steering rack. I'm gonna do it. I took the DS bracket off to make a new one, I'll let you dudes know how it goes. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted February 14, 2010 Share Posted February 14, 2010 Post pics of this mod. I'm definitely interested in seeing how this works. Link to comment Share on other sites More sharing options...
180sx Posted February 18, 2010 Share Posted February 18, 2010 yea I want to know also. Do you think your are going to have to modify the sub-frame for the rack being turned? Link to comment Share on other sites More sharing options...
new4x4r Posted February 18, 2010 Share Posted February 18, 2010 It doesn't look like it. The wrack only has that "egg" shape on the top. I'm only turning it about 20 degrees to line up with the part of the steering shaft that has to be lengthened. so the Side of the steering rack thats touching the subframe is the same shape it was before. The only problem I can see running into, is the bolt going back in for the top of the bracket. The one hard-line going into the rack is probably going to be in the way. I'll post pics when I get the new bracket back... Tomorrow! Link to comment Share on other sites More sharing options...
180sx Posted February 23, 2010 Share Posted February 23, 2010 Update? Link to comment Share on other sites More sharing options...
new4x4r Posted February 23, 2010 Share Posted February 23, 2010 Nothing to report right now. I'll finish the steering up tomorrow night and let you know how it goes. I fit it up with no problems, just need to bolt everything together now and see how it works Link to comment Share on other sites More sharing options...
new4x4r Posted February 24, 2010 Share Posted February 24, 2010 So rotating the rack and extending the shaft didn't work. It was ff by 1/4". But with the rack rotated, theres pretty well no angle so the two Ujoints will have no problem with binding. Link to comment Share on other sites More sharing options...
180sx Posted February 25, 2010 Share Posted February 25, 2010 What do you mean off by 1/4"? Picture maybe? Link to comment Share on other sites More sharing options...
new4x4r Posted February 25, 2010 Share Posted February 25, 2010 I'll take a pic tonight. When its on the rack, with the shaft extended it can't line up to the rubber steering link. one side of the extension (where it bolts in) but the other side is off by 1/4". It would need a wedge or something to take up the space. But it would seriously bind when turning if you do that. But rotating it wasn't a total waste. Now the angles are straighter Link to comment Share on other sites More sharing options...
new4x4r Posted March 5, 2010 Share Posted March 5, 2010 So here it is in most of its glory(minus the bigger tires)! It doesn't look as big anymore to me. The front end is a bit low. I have to put the new struts in with the insulators/bushings on top. I just threw the old ones in to get it out of the garage. The steering. I had to use the Ujoint method to get it linked up. I just bought a 3/4" Ujoint and welded it up to the factory one. Panhard Drop. 2x4" tube with 3/8" plate. dropped 4" Link to comment Share on other sites More sharing options...
fleurys Posted March 5, 2010 Share Posted March 5, 2010 wow...you did not sit on your a$$ did ya ! can't wait to see the final product ... Bravo. Link to comment Share on other sites More sharing options...
shift220 Posted March 5, 2010 Author Share Posted March 5, 2010 Looks absolutely great man. Do a little grinding to get that 2" x 4" tube up in the panhard bar slot? Definitely a lot easier to make then mine. Any pics of the steering rack? I'd like to rotate mine as well. Link to comment Share on other sites More sharing options...
new4x4r Posted March 5, 2010 Share Posted March 5, 2010 Yeah I had to grind and hammer the thing into submission. I'll take some pics of the rack. Its really easy to do. Just remove the stock carriers or brackets, rotate it to where you want it, Use a piece of stiff (but flexible) wire to get the inside shape of the angles you want, then cut the original bracket, weld a piece and grind... Link to comment Share on other sites More sharing options...
Adventure51 Posted March 15, 2010 Share Posted March 15, 2010 What size tires do you have in those pictures? And what size do you plan on going to? Is it a 4" SFD plus a 2" suspension lift? It looks great! I just got my 4" SFD kit from Shift220 and can't wait to install it. Later, Kevin Link to comment Share on other sites More sharing options...
new4x4r Posted March 15, 2010 Share Posted March 15, 2010 4" SFD, 2" AC coils (front) and those are Mickey Thompson's best attempt at a 31 (29.5" actual). I'm going to 35's as soon as I can! Good on ya getting the kit from him! He's the one I took all the info from, so he knows what he's doing.. and if he doesn't, he fakes it really well. Link to comment Share on other sites More sharing options...
Adventure51 Posted March 15, 2010 Share Posted March 15, 2010 Hahaha!!! He is a great guy to deal with. I just received the kit from him the other day and it looks professional!!! I am planning on going with 305/70/16's BF Goodrich M/T (33.1 inches) but am wondering if 315/75/16's BF Goodrich M/T (34.8 inches) would look and work better with the 6 inches of lift. What do you think I should go with between the two? Of course I would love to go with the bigger tires but I'm wondering if they will clear the wheel wells for offroading. Later, Kevin Link to comment Share on other sites More sharing options...
shift220 Posted March 15, 2010 Author Share Posted March 15, 2010 ...I found a great way to rotate the steering rack using the stock bracket and a hammer. Thanks for the tip on using wire to get the shape! No cutting, grinding or welding required either Link to comment Share on other sites More sharing options...
Adventure51 Posted March 15, 2010 Share Posted March 15, 2010 Sweet! You'll have to let us know how you did it. Do you have any pics Andrew? Link to comment Share on other sites More sharing options...
new4x4r Posted March 15, 2010 Share Posted March 15, 2010 I'm actually getting the second of the two BFG KM's... So I'll let you know what you need to cut to fit them in. Its just a matter of gearing once you get them to stop rubbing. Thats next on my list! Yeah the Wire idea worked well, the problem was, that was a loose fitment. So I had to weld a piece of bar inside to tighten it up on the bushing. But the shape was bang on! Link to comment Share on other sites More sharing options...
muddfildvaynes Posted March 15, 2010 Share Posted March 15, 2010 I'm actually getting the second of the two BFG KM's... So I'll let you know what you need to cut to fit them in. Its just a matter of gearing once you get them to stop rubbing. Thats next on my list! Yeah the Wire idea worked well, the problem was, that was a loose fitment. So I had to weld a piece of bar inside to tighten it up on the bushing. But the shape was bang on! What shocks did you end up useing? Link to comment Share on other sites More sharing options...
new4x4r Posted March 15, 2010 Share Posted March 15, 2010 I used Pro Comp ES 9000 P/N 929500 Link to comment Share on other sites More sharing options...
