ditchdiggerjcf Posted July 16, 2009 Share Posted July 16, 2009 I just got my truck out of the shop after having the passenger side exhaust manifold replaced. The truck ran like a new one after the repairs were made, but now I have a problem. I washed the engine yesterday at the car wash and now my truck runs like s**t. I did not go nuts with the high pressure sprayer, but It was enough to get water somewhere that it should not be. Where are the nissan trucks susceptible to water intrusion? Link to comment Share on other sites More sharing options...
darkestskydiver Posted July 16, 2009 Share Posted July 16, 2009 i would check under the dizzy cap water likes to hide there. Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted July 16, 2009 Author Share Posted July 16, 2009 i would check under the dizzy cap water likes to hide there. I haven't looked anywhere yet, but I figured if it was somewhere like that it would have evaporated already. Any thoughts? Link to comment Share on other sites More sharing options...
BowTied Posted July 17, 2009 Share Posted July 17, 2009 Dist cap and spark plug wires (esp if they are older, they could soak some water). Very god chance that if you leave it over night it will be fine in the morning. If you can't wait, some water displacement spray (ie WD40) should help, just don't get it all over the place (flammable) Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted July 17, 2009 Author Share Posted July 17, 2009 Dist cap and spark plug wires (esp if they are older, they could soak some water). Very god chance that if you leave it over night it will be fine in the morning. If you can't wait, some water displacement spray (ie WD40) should help, just don't get it all over the place (flammable) I did it yesterday, and the engine is still running terrible as of this evening. What could it be? I might have to put it back in the shop in the morning, because I need it to tow the boat this weekend. Link to comment Share on other sites More sharing options...
BowTied Posted July 17, 2009 Share Posted July 17, 2009 It could be wet ignition components, dist cap, coil, wires. Could be several things, but that seems most likey... Link to comment Share on other sites More sharing options...
daver123 Posted July 17, 2009 Share Posted July 17, 2009 I have had my truck run like sh*t after getting it wet as well and my problem would always clear up after a few minutes. I would have to agree with the other guys though and say start checking the ignition components. Link to comment Share on other sites More sharing options...
k9sar Posted July 17, 2009 Share Posted July 17, 2009 I always suggest to check the connector ont he top of the MAF. It's a known weak spot on the WD21's. Pull the connector, make sure it's dry inside, put it back together, start it up. If she runs fine, that was your problem. If not, wiggle/flex the wire and connector on top to see if it makes a difference. 1 Link to comment Share on other sites More sharing options...
Precise1 Posted July 17, 2009 Share Posted July 17, 2009 B Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted July 18, 2009 Author Share Posted July 18, 2009 I just got my truck out of the shop after having the passenger side exhaust manifold replaced. The truck ran like a new one after the repairs were made, but now I have a problem. I washed the engine yesterday at the car wash and now my truck runs like s**t. I did not go nuts with the high pressure sprayer, but It was enough to get water somewhere that it should not be. Where are the nissan trucks susceptible to water intrusion? Truck is running alright again, I can't believe it took almost 3 days to dry out. One other note, after it came back from the shop I went from getting 280 miles per tank to 350 per tank. Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted July 19, 2009 Author Share Posted July 19, 2009 I just got my truck out of the shop after having the passenger side exhaust manifold replaced. The truck ran like a new one after the repairs were made, but now I have a problem. I washed the engine yesterday at the car wash and now my truck runs like s**t. I did not go nuts with the high pressure sprayer, but It was enough to get water somewhere that it should not be. Where are the nissan trucks susceptible to water intrusion? Pulled the boat today for the 1st time since I got my truck out of the repair shop. I don't know exactly what the mechanic did to my little rig but it pulled the boat with some authority. I'm impressed. I didn't even need 4low to pull the boat up the launch ramp. Link to comment Share on other sites More sharing options...
Jeffrey Posted July 19, 2009 Share Posted July 19, 2009 I recently had my manifold replaced as well, and like you I'm seeing a reasonable improvement. I hope that with a new high-flow cat back exhaust system, I'll be able to really notice some improvement. 154k on stock exhaust probably not getting all 150 ponies working for me now. Link to comment Share on other sites More sharing options...
ditchdiggerjcf Posted July 19, 2009 Author Share Posted July 19, 2009 I recently had my manifold replaced as well, and like you I'm seeing a reasonable improvement. I hope that with a new high-flow cat back exhaust system, I'll be able to really notice some improvement. 154k on stock exhaust probably not getting all 150 ponies working for me now. I know some folks around here get a little pissy about this, but, he ditched the cat on my truck. The improvement in how well my truck runs is way, way more than reasonable. My truck can now accelerate up hills with the boat in tow. I think that is pretty impresive. By the way, the boat probably weighs a little over 3k pounds. My fuel mileage also improved dramatically. Link to comment Share on other sites More sharing options...
