Never assume your rust isn't that bad
adamzan
The previous owner said he fixed it. Must've done a crappy job.
http://s269.photobucket.com/albums/jj74/ad...e%20in%20floor/
Fixed ?? you mean cover up... mine wasn't that bad... until i started to smell burnt rubber...it was my shoe melting on the muffler pipe.... i realy hesitate buying a Path in our area...
Since I had the exhaust replaced the new pipes seem to have been relocated away from that area...Redesigned maybe? The floor never gets hot at all.
I guess I'll just do the baking sheet fix to get me down to nismo junkys place. although I suspect the last two times I was in that area the hole was there LOL.
Did you check these ? ...i don't know how you call them ...i remember, my mechanic had to refabricate 3 of them on one side and two on the passenger side. ... support the body on the frame... the frame itself was ok but the flooring gave way... 4 on each side hein ? you must be floating under your feet ?
Edited by Pinip
If any of them are going to be bad, its going to be that one. Every other part of the floor and body is in mint condition under there, it's all been undercoated many times as you can see on the frame there. I don't know why that fender well and rocker got so bad. I know why the floor has a hole, that was from my leaky exhaust.
no i dont mean cover up i mean cut out the old and bend some sheet metal and weild it in or rivit and then use some fibgerglass around the seems then cover it in undercoat it will out last the truck
HOLY MACRO !
Some pictures looks like a view of a cave or something ! that looks like dangerously rusted !
If it is dangerous, thats too bad because it is my only mode of transportation right now :thumbsdown:
... not any worst than the Flintstones...as long as the frame and the mechanic are safe...!!! if your vehicule can withstand those craters in our roads... it is road worthy...!!!
...Difficult to understand, why in Canada, we win the International Rust Trophee... year after year... as if, no other country had to deal with snow, ice and slutch... simply...inconcevable !!
There are alternatives to salting the roads. Like people learning to drive properly. Though we know that will never happen!
So in two weeks I will drive to brantford to help nismojunky and hopefully we can get this rust all patched up. Great time to bring out the mig welder! :fireworx:
...Just like i did (my mechano) ...lot's of cutting and welding (reeveting is not legal anymore in Quebec)... we did all the flooring , driver, passenger, under the back seat ( that was free air conditioning in winter...holes 2'x2' ),rebuilted 6 body supports on the frame, replaced both front fenders, counter panel ( under the hatch door ?) rocker panels, also around the lower frame of the back doors... then, painted and tared everything... it was a lot of work...worthed though...until the accident... at least i know, how and where a Pathfinder rusts... :shrug:
Happy rebuilding and lots of welding !!
Edited by Pinip
Riveting is illegal there? Damn. Thats how the current "patch" is being held in. This time it will be welded. If not I will rivet as best as I can.
Yes ...in Quebec...i don't know about the other provinces...anyway , you are better of welding (tig or mig ? i am not a welder...)... if you want to keep your truck for a long time...riveting is artisanal but not as resistant...!!
Edited by Pinip
