michael Posted March 31, 2009 Share Posted March 31, 2009 does anyone know the tooth count between the timing gears on a vg30e engine Link to comment Share on other sites More sharing options...
Precise1 Posted March 31, 2009 Share Posted March 31, 2009 Not until I can get home to some manuals. It has been posted many times is timing belt threads so if you need the information immediately, search would be your best friend. B Link to comment Share on other sites More sharing options...
MY1PATH Posted March 31, 2009 Share Posted March 31, 2009 From my Nissan PDF Total teeth on belt 133 NUBER OF TEETH BETWEEN TIMING MARKS; Between LH & RH camshaft sprockets 40 Between LH camshaft sprocket and crankshaft timing sprocket 43 does your belt not have alignment marks on it? Link to comment Share on other sites More sharing options...
michael Posted April 1, 2009 Author Share Posted April 1, 2009 yes my timing belt does have marks but there is no mark on the crank sprocket for me to line the mark up to Link to comment Share on other sites More sharing options...
MY1PATH Posted April 1, 2009 Share Posted April 1, 2009 yes my timing belt does have marks but there is no mark on the crank sprocket for me to line the mark up to !?!? My guess would me to be damn sure the crank is @ #1 tdc but that seems sketchy to me... Link to comment Share on other sites More sharing options...
michael Posted April 1, 2009 Author Share Posted April 1, 2009 ya i know what your saying there thats why im afraid to start putting it back together but i have a theory that a previous owner has taken it apart and put the crank sprocket on backwards only problem with that is that i cant seem to get the sprocket off to see if my theory is correct Link to comment Share on other sites More sharing options...
GrimGreg Posted April 1, 2009 Share Posted April 1, 2009 I know my sprocket had a mark, but no mark to line it up with. Link to comment Share on other sites More sharing options...
Indigent Posted April 1, 2009 Share Posted April 1, 2009 (edited) The sprocket is flat on the side that points away from the engine. The side that points TO the engine has a channel machined into it. So if you see the flat side staring at you, it is probably correct. You should take that sprocket off anyway to do the crank seal. There is absolutely no reason to skip doing your crank and cam seals while you are in there doing the belt. The seals are less than $5 each. That is a pretty cheap insurance policy. Edited April 1, 2009 by Indigent Link to comment Share on other sites More sharing options...
Simon Posted April 1, 2009 Share Posted April 1, 2009 The sprocket is flat on the side that points away from the engine. The side that points TO the engine has a channel machined into it. So if you see the flat side staring at you, it is probably correct. You should take that sprocket off anyway to do the crank seal. There is absolutely no reason to skip doing your crank and cam seals while you are in there doing the belt. The seals are less than $5 each. That is a pretty cheap insurance policy. While I agree with the logic presented here, I, personally, do not touch the cam or crank seals when doing the timing belt. I am always afraid that I will cause a leak by improperly installing the seals, or by loosening some crud that's holding the oil in the engine. This is something where I believe "if it ain't broke, don't fix it". Hasn't failed me yet. Link to comment Share on other sites More sharing options...
michael Posted April 1, 2009 Author Share Posted April 1, 2009 ok thanks alot im pretty sure i got it figured out Link to comment Share on other sites More sharing options...
MY1PATH Posted April 1, 2009 Share Posted April 1, 2009 could you scale down your sig pic please? Link to comment Share on other sites More sharing options...
Kingman Posted April 1, 2009 Share Posted April 1, 2009 Beat me to it! Link to comment Share on other sites More sharing options...
94extreme Posted April 1, 2009 Share Posted April 1, 2009 While I agree with the logic presented here, I, personally, do not touch the cam or crank seals when doing the timing belt. I am always afraid that I will cause a leak by improperly installing the seals, or by loosening some crud that's holding the oil in the engine. This is something where I believe "if it ain't broke, don't fix it". Hasn't failed me yet. same here on this particular item. i'll take care of his sig in a minute. Link to comment Share on other sites More sharing options...
michael Posted April 2, 2009 Author Share Posted April 2, 2009 could you scale down your sig pic please? ya it went away somehow is wished i could have i didnt know how though but i would have been glad to do that Link to comment Share on other sites More sharing options...
MY1PATH Posted April 2, 2009 Share Posted April 2, 2009 ya it went away somehow is wished i could have i didnt know how though but i would have been glad to do that I think a mod took it away for viewing ease. I'm sure there will be no problem if you re-post it as long as it is smaller. Link to comment Share on other sites More sharing options...
94extreme Posted April 2, 2009 Share Posted April 2, 2009 I think a mod took it away for viewing ease. I'm sure there will be no problem if you re-post it as long as it is smaller. right and i made it a link. someone else made it go away completely. Link to comment Share on other sites More sharing options...
