White Lightnin Performance Module
joseph
Complete rip-off. It's a 5 cent resistor. It tricks your ECM into thinking you're getting less airflow so it cuts the fuel down...basically just leaning out your engine and making your truck run like crap, which is then read by the O2 sensors, and the ECM compensates by triggering a check engine light saying that your MAF is malfunctioning, then runs you in closed loop, which uses more fuel.
...runs you in closed loop, which uses more fuel.
Correction: open loop.
Closed-loop uses the O2 sensors to calculate A/F ratio. Open-loop uses the preset computer A/F maps, which is usually much richer than needed.
I did some research a while back on TB spacers. The reported gains versus the actual gains have not been proven in any way shape or form EXCEPT by the manufacturer, and what would they have to gain by falsifying dyno sheets or power increases? ;)
Any time I saw a dyno before/after test they always did it with several mods, not JUST the addition of a spacer. Like, "Oh, we added a NEW EXHAUST and a TB spacer and gained 14 HP!!!" RIIIIIGHT.
