180sx Posted January 14, 2009 Share Posted January 14, 2009 (edited) Hello... So, I've had this Pathy for a little over a year now. The auto thing has been fun, but my car is auto also (the wifes) and its just plain boring. So i want to swap in a 5spd to get my balls tingling a little again. Just want to make sure I have a list of all that I need. Don't know about pathy's Trans' much. 5spd Trans 5spd ECU Clutch pedal Clutch Master Cylinder Slave Cylinder Flywheel Clutch pressure plate throw out bearing pilot bushing lines center console items (under consle, shifter insert, ect...) starter (maybe?) check drive shaft lengths check for spacer behind flywheel. Am I missing anything? Or will I need to get new driveshafts also? Oh, its a 4WD model, and a '96. Thanks, Jose Edited January 15, 2009 by 180sx Link to comment Share on other sites More sharing options...
01silvapathy Posted January 14, 2009 Share Posted January 14, 2009 I have no idea on how to go about doing this but, one thing that I thought of, A new center Console, or are you just going to cut out a place for the shifter knob?? Link to comment Share on other sites More sharing options...
180sx Posted January 14, 2009 Author Share Posted January 14, 2009 I have no idea on how to go about doing this but, one thing that I thought of, A new center Console, or are you just going to cut out a place for the shifter knob?? all ready have center console in my list. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted January 14, 2009 Share Posted January 14, 2009 That's a hefty undertaking but all the best to ya! Link to comment Share on other sites More sharing options...
01silvapathy Posted January 14, 2009 Share Posted January 14, 2009 all ready have center console in my list. WOW...It was early....leave me alone "goes back into corner" Link to comment Share on other sites More sharing options...
nissandoms47 Posted January 14, 2009 Share Posted January 14, 2009 You dont need the entire center console just the trim that houses the boots for the shifters. It'll snap right in place of the auto one. You might also wanna get the floor pan rubber boots and stuff that goes under the console. Link to comment Share on other sites More sharing options...
tekazgtr1984 Posted January 14, 2009 Share Posted January 14, 2009 You dont need the entire center console just the trim that houses the boots for the shifters. It'll snap right in place of the auto one. You might also wanna get the floor pan rubber boots and stuff that goes under the console. Sounds easier than I thought. So you're saying a 5-spd VG30DETT swap is possible...? Link to comment Share on other sites More sharing options...
BowTied Posted January 14, 2009 Share Posted January 14, 2009 Pilot bearing or bushing is something to add, also Throw out bearing trans oil Are the driveshafts the same length? I presume the speedo connection would be the same. You'll need to deal with the trans cooling line removal and plug the rad. All I can think of right now. Link to comment Share on other sites More sharing options...
nunya Posted January 14, 2009 Share Posted January 14, 2009 Little piece of info that may or may not be useful, since my experience is a little different and don't know if it would even come to play with a r50. When I had to swap motors in my old HB(91 2.4l 5speed 4x4) the motor I dropped in was from an auto equipped truck. Didn't pay atention and there was a small spacer between the flywheel and crank on the auto equipped motor and when switching flywheels it stayed on the crank and actually held the flywheel out like 1/4". Starter chewed the teeth off the flywheel in a matter of a week. MAKE SURE TO REMOVE THE SPACER WHILE YOU HAVE THE FLYWHEEL OFF. That and make sure you get a pressure plate with your clutch kit. Link to comment Share on other sites More sharing options...
180sx Posted January 15, 2009 Author Share Posted January 15, 2009 (edited) Hey, Thanks for all the replies! Good info on the spacer behind the flywheel. I'll have to look at that. So far it sounds like a straight forward swap. I'll be sure to do a write up in the future when I do this. Won't be any time too soon. probably june when its comfortable to be at the junk yard and my tax return settles all my debts...maybe sooner. but definately this summer. Thanks again! Oh, and another thing. does anybody know if the transfer cases will swap? or is it best to leave the tranfer case on each trannny? sorry, i am new at this 4x4 thing, so i'm not very familiar with this.. Edited January 15, 2009 by 180sx Link to comment Share on other sites More sharing options...
tmorgan4 Posted January 15, 2009 Share Posted January 15, 2009 I don't have everything you need, but I do have a flywheel and 5 speed ECU. Link to comment Share on other sites More sharing options...
vengeful Posted January 15, 2009 Share Posted January 15, 2009 Here's an exhaustive PDF guide of everything you will need, and step by step directions: http://www.overlandtrucks.com/system-f/NPTC.pdf Link to comment Share on other sites More sharing options...
180sx Posted January 16, 2009 Author Share Posted January 16, 2009 HOLY CRAP!!! This is exact;y what i've been looking for!! And WOW...this is alot more difficult than most other cars...well, the wiring part at least is a little different...no biggie. Thanks Bro! Link to comment Share on other sites More sharing options...
