My new work bench
shift220
So after getting fed up with the wood work bench that I had in my garage, I finally gave in and made myself a new metal one. The old bench was roughly 12" deep and 6 feet long which made for a crappy work area. The new one is 27" deep and 7 feet long with a galvanized sheet metal cover. I used 1.5" square tubing and some 1" angle iron for the shelf. The left side is reserved for TIG welding, I just need a nice bar stool to go there. On with the pictures...
I still want to put on short legs and put in another piece of plywood for the bottom shelf. Let me know what you think!
(the vice should be on the heavy/braced end, just my experience)
I think that kinda defeats the TIG use of it. I think he put it there so he wouldn't be working over his storage.
Nice clean bench man!
Thanks guys. I'm excited to use it myself. I should have taken more pictures when I was making it to show you guys the fabrication and what not. The vice is bolted to the tubing on all four corners so it is fully braced and I won't be to hard on it anyway.
The top was made by a company that deals only with sheet metal forming like that, next door to my shop. They did an awesome job bending it.
Yep, my bad, that didn't filter in. Part of it was the 'work bench'. The few welders that I knew had a seperate section for welding only, usually a heavy cart with a metal top...
Besides, I see a vice on a bench and I think it is going to be used for hammering or torquing... :D
