daopi Posted April 30, 2008 Share Posted April 30, 2008 I have a 97 XE, so stock tires are 235/70R15. I'm planning to change to 31" tires, but in theory that means 10% bigger and 10% less power, plus ABS system will be confused. This is what I know. As I saw here, most of you guys installed 31" or bigger tires, so my question is what is happening in real life with the power of the car and with the brakes. Is it something I should care or is not a big deal for the car? Don't forget I have an XE, not an SE, so stock means like 28" tires. Thanks! Link to comment Share on other sites More sharing options...
csutke Posted April 30, 2008 Share Posted April 30, 2008 you will feel a little bit of a difference with the bigger tires, as for stopping i never noticed a difference but thats because i went from 30x9.5 to 31's as thats what was on it when i bought it. a few other things to remember is your ODO will be off by about 10%. but there are ways around that, such as regearing or getting a dash hawk. Link to comment Share on other sites More sharing options...
Fukinitupagain Posted April 30, 2008 Share Posted April 30, 2008 I have a 97 XE, so stock tires are 235/70R15. I'm planning to change to 31" tires, but in theory that means 10% bigger and 10% less power, plus ABS system will be confused. This is what I know. As I saw here, most of you guys installed 31" or bigger tires, so my question is what is happening in real life with the power of the car and with the brakes. Is it something I should care or is not a big deal for the car? Don't forget I have an XE, not an SE, so stock means like 28" tires. Thanks! I have an SE so my stock tire was pretty well a 31 so there wasn't a difference except for better traction in mud & a louder noise on the road (highway speeds you don't notice it) Link to comment Share on other sites More sharing options...
laxman0324 Posted April 30, 2008 Share Posted April 30, 2008 I have an SE so my stock tire was pretty well a 31 so there wasn't a difference except for better traction in mud & a louder noise on the road (highway speeds you don't notice it) my 97 SE is rated stock for 265/70 R15, which is about the same size as 30x9.5, just a little smaller Link to comment Share on other sites More sharing options...
Simon Posted April 30, 2008 Share Posted April 30, 2008 Your brakes will be fine. I don't know why you think your ABS would be "confused". The only way that would happen is if you were running larger tires on one axle, in comparison to the other, or two different sized tires on 1 axle. Either way, with all 4 being larger, your ABS will be fine. Link to comment Share on other sites More sharing options...
FUELER Posted April 30, 2008 Share Posted April 30, 2008 my R50 couldnt lock up my 32" tires, or engage ABS, if my life depended on it. Link to comment Share on other sites More sharing options...
XPLORx4 Posted April 30, 2008 Share Posted April 30, 2008 If you're using the stock XE 15x6.5 steel wheels, you'll need to replace them with wider wheels (recommend 15x8 with 3.75 to 4" backspacing) to fit 31" or larger tires. Your XE also has tall 4.363:1 gears, intended for use with small tires, so you will definitely feel the difference in reduced acceleration with 31" tires. The ABS system won't get confused at all. The sensors are on each wheel hub. It will just think you're going slower. ABS works just fine on my '97 LE with 32" tires, although to get it to engage, I had to upgrade my front brake rotors. Link to comment Share on other sites More sharing options...
daopi Posted May 1, 2008 Author Share Posted May 1, 2008 ABS works just fine on my '97 LE with 32" tires, although to get it to engage, I had to upgrade my front brake rotors. What kind of upgrade? Link to comment Share on other sites More sharing options...
XPLORx4 Posted May 1, 2008 Share Posted May 1, 2008 What kind of upgrade? This kind: Powerstop Rotors Link to comment Share on other sites More sharing options...
90seven Posted May 3, 2008 Share Posted May 3, 2008 Unless you're driving your Pathy on race track or speeding down the Lions Back, your stock rotors should be sufficient. As said, ODO will be off a minor bit. Other than that, its really is unoticable. I, personally, am going to revert back to stock wheels and 30s for the sake of better fuel economy. Link to comment Share on other sites More sharing options...
XPLORx4 Posted May 5, 2008 Share Posted May 5, 2008 Unless you're driving your Pathy on race track or speeding down the Lions Back, your stock rotors should be sufficient. Yeah, stock rotors and pads will be fine with 31" tires. I lost effective ABS functionality for emergency stopping on pavement when I got steel wheels and 32" MTR's, which is why I upgraded. Link to comment Share on other sites More sharing options...
