Andrew Posted November 5, 2007 Share Posted November 5, 2007 My pathfinder has been sitting for a little while since I am saving up to get the timing belt replaced. I drove it to the store yesterday and it was making a metal clanging noise that sounded like it was coming from the front right wheel. It got faster when the car when faster and stopped completely when the car wasnt moving. Any idea at all when this could be? Thanks. Link to comment Share on other sites More sharing options...
GrimGreg Posted November 5, 2007 Share Posted November 5, 2007 My pathfinder has been sitting for a little while since I am saving up to get the timing beltreplaced. I drove it to the store yesterday and it was making a metal clanging noise that sounded like it was coming from the front right wheel. It got faster when the car when faster and stopped completely when the car wasnt moving. Any idea at all when this could be? Thanks. Dust sheild on the disc brake maybe. Link to comment Share on other sites More sharing options...
Andrew Posted November 6, 2007 Author Share Posted November 6, 2007 So if I take off that wheel, how do I check and see if it is that? Link to comment Share on other sites More sharing options...
Simon Posted November 6, 2007 Share Posted November 6, 2007 Jack it up, spin the wheel...listen for where the noise is coming from.. Could have also been a bad hub trying to lock, or a bad wheel bearing. Link to comment Share on other sites More sharing options...
texasbudman Posted November 7, 2007 Share Posted November 7, 2007 (edited) So if I take off that wheel, how do I check and see if it is that? If you jack it up, put it on stand since you got it up... when you take off the tire and anything falls off there is your problem... ck for loose or funny things... How do you know whats loose or funny, you maybe thinking... take off the other tire and use the other side as a point of referance... hence put it on a stand (DON'T USE CEMENT BLOCKS!!!! unless you have Sucidal Tendancies)... Edited November 7, 2007 by texasbudman Link to comment Share on other sites More sharing options...
Mr. Pickles Posted November 8, 2007 Share Posted November 8, 2007 Dust sheild on the disc brake maybe. Ditto this, its pretty common. I had it several years ago. No biggie. Link to comment Share on other sites More sharing options...
94extreme Posted November 8, 2007 Share Posted November 8, 2007 yeah.. crawl under there and have a looksy. Link to comment Share on other sites More sharing options...
