Newbie Forum Member With '94 Pathfinder
flatwins
Hi all. I'm a newbie to the forum and my wife's primary driver is a '94 Pathfinder which we bought in the summer of '02 with 58k miles. Its been a good ride for the most part and now has like 129k. Its mainly a kid hauler and is not used for offroad or anything like that. I've done the water pump, timing belt, half shaft, brakes, etc. on it. We've had some minor electrical issues with it which I've farmed out (I don't usually mess with that stuff). This thing isn't our favorite vehicle but its been good to us and we plan to keep it a little longer before diving into car payments again.
I'm going to post in the mechanical section because the front end of this thing is needing some attention. Both front tires are wearing their inside corners something fierce. Almost like everything is sagging. I just need to know what to look for\replace\etc. on the front end.
Thanks in advance guys and girls!
Steve
Tulsa, OK
Welcome!
Chances are, you've either got bad ball joints, tie rods, or possibly, a bad centerlink, as they're known to go on these things. At any rate, not too bad a fix.
When an inner or outer rib wears faster than than the rest of the tire, the need for wheel alignment is indicated. There is excessive camber in the front suspension, causing the wheel to lean too much to the inside or outside and putting too much load on one side of the tire. The car may simply need the wheels aligned, but misalignment could be due to sagging springs, worn ball joints, or worn control arm bushings.
Just to add to this, it can also be toe out that causes the inside edge to wear. Having said that, it is most likely that the T-bars have sagged with age. Best idea is to get a W/A (a good one).
Oh and welcome to the family WAVEY
