body lift bolt question
Guest SuperSon
Guest SuperSon
Is there something special about this bolt?
I ordered my kit on ebay but its for a hardbody and was told that it would work if I get a different bolt for the rear. If I take out the rear factory bolt that I have on there right now can I just take it to a local bolt shop and get the same one as far as the size and pitch but longer by maybe 2.5 inches?
Looking from underneath the pathy I noticed that bolt 3 and 5 are reversed from the other 3 meaning the head of the bolt is in the bottom. does this have a welded nut on the the body or do I have to remove the carpeting to get another socket for the nut?
does it matter where I place the new lift blocks from the kit?I was thinking under the factory rubber blocks since its going to be sitting on thicker plate on the frame and the rubber against the body
Heres some stuff ive gathered so far to do this lift .
1 New Upper Radiator Hose
4' 5/8" Heater Hose: For power steering and fuel vent lines
4' 3/8" "Transmission Cooler Line" Hose: For power steering (got extra 2 feet for tranny cooler upgrade)
different size hose clamp
2 24 inch piece of 4X4
Some people have been able to location those bolts while others have not. It's worth a try, take them down to your local hardware store and ask.
If you have a specialty bolt/fastener store, even better :aok:
Guest SuperSon
theres 2 vacuum hoses that I had to replace/extend in the pass front fenderwell
What size hose are they?
Guest SuperSon
Yeah theres a couple of specialty nut and bolt shop around here. Thats where I found my spindle bolts :D
Guest SuperSon
Found out that the bolt that came with the 86-90 kit 4053 is a 10X180MM. Does the bolt for the 91-95 has to be longer or shorter?
Guest SuperSon
Pull one out and measure it, then add 3".
Got it.Nothing special about that bolt then I guess? As long as I get one thats 3 inches longer than the factory one I have and not a full threaded bolt.
Thanks
Edited by SuperSon
Guest SuperSon
Well I picked up a couple of 10X180MM bolts today just to make sure just in case the 86-90 pathfinder body lift kit doesnt come with a couple of this size.
I asked headspace what his bl bolts in the rearmost mounts are and it was 10X180MM. It says on the 4053 BL kit for the 86-90 pathy that it came with a 10X180MM grade 5 bolts :confused:
Its a 10X180MM with a 1.5 thread pitch.Hope this works and I will keep you guys updated
Guest SuperSon
This is a M10X180 with a 1.25 (not 1.5) thread pitch.
Me and the guy at fasteners both measured the pitch and its at 1.5 using a bolt gauge or are you saying its supposed to be a 1.25 pitch?
Edited by SuperSon
For 3" body lift
3-d pair - M10x180x1.25
5-th pair - M10x180x1.25 (3 doors) or M12x180x1.25 (5 doors)
the thread pitch wont matter too much as long as you have the right nuts...i think that with the 1.5 thread pitch you will loose some gripping force but i would think it would be fine...I would def make sure they were a quality grade 8 bolt (not lowes or home depot grade 8) and i believe the rule of thumb is make sure after its torqued down that u have at least 5 threads beyond the nut...
some1 can correct me if im wrong but i believe that is the case...its just my intuition not really based on any specific fact
The reason for the specific bolts in the rear, and 3rd holes is because there are captive nuts in the truck that you can't get at. Correct pitch is necessary.
Guest SuperSon
Now I know why this bolt is so special.cant find one that long .I was able to locate a 1.25 pitch (fine thread) in a M12 but the longest one that every online store carries is 100MM. I found a thread that a M12X180 1.25 pitch is being used on a lot of european cars on the transmission.
gotta do some more searching
Such bolts may be here:
http://www.wurth.com/
Action Bolt & Tool Co.
2051 Blue Heron
Boulevard West
Riviera Beach
Florida 33404
USA
+1 561 845-88 00
+1 561 845-02 55
e-Mail: actionlp@actionboltandtool.com
http://www.actionboltandtool.com
Würth Line North America
Adams Nut & Bolt Co.
PO Box 207
10100 85th Ave. North
Maple Grove
Minnesota 55369
USA
+1 763 4 243 374
+1 763 4 930 800
e-Mail: info@wurthadams.com
http://www.wurthadams.com
Baer Supply Company
909 Forest Edge Drive
Vernon Hills
Illinois 60061
USA
+1 847 913 22 37
+1 847 913 96 06
e-Mail: info@BaerSupply.com
http://www.BaerSupply.com
Brikksen Inc.
10421 Sanden Drive
Dallas, TX 75238
USA
+1 214 3 435 703
+1 214 3 486 990
e-Mail: purchasing@brikksen.com
http://www.brikksen.com
Screws and Standard Parts - International
Grass America Inc.
1202 Highway 66S
Kernersville, NC 27284
USA
+1 336 996 40 41
+1 336 996 51 49
http://www.grassusa.com
Production - International
Louis and Company
P.O. Box 2253
Brea, California 92822
USA
+1 714 5 291 771
+1 714 9 906 184
e-Mail: marketing@louisandcompany.com
http://www.louisandcompany.com
Mepla-Alfit, Inc.
P.O. Box 1666
130 Lexington Parkway
Lexington,
North Carolina 27295
USA
+1 336 956 46 00
+1 336 956 47 50
http://www.mepla-alfit.com
RevCar Fasteners Inc.
3845 Thirlane Road
Roanoke, Virginia 24019
USA
+1 540 5 616 565
+1 540 5 616 577
e-Mail: info@revcar.com
http://www.wurthrevcar.com
Trend Distributors, Inc.
2800 S.W. 42nd Street
Ft. Lauderdale, FL 33312
USA
+1 954 3 217 220
+1 954 3 217 250
e-Mail: info@trenddistributors.com
http://www.trenddistributors.com
Würth Eastern Maintenance and
Industrial Supplies, Inc.
P.O. Box 8128
199 White Oak Drive
Berlin, CT 06037
USA
+1 860 8 290 556
+1 860 8 290 552
e-Mail: info@wurtheastern.com
http://www.wurtheastern.com
Würth McAllen Bolt & Screw, CO
4403 W. Military Hwy Ste 500A
McAllen, TX 78503
USA
+1 956 687 85 96
+1 956 687 79 40
e-Mail: info@wurthmcallen.com
http://www.wurthmcallen.com
Würth Snider Bolt & Screw, Inc.
11503 Champions Way
Louisville, Kentucky 40299
USA
+1 502 9 682 250
+1 502 9 682 278
e-Mail: info@sniderbolt.com
http://www.wurthsnider.com
Wurth Electronics Inc.
EMC & Inductive Solutions
91 Grant Street
Ramsey, NJ 07446
USA
+1 201 7 858 800
+1 201 7 858 810
e-Mail: eisos-usa@we-online.com
http://www.we-online.com
Electronics - International
Wurth Electronics Midcom Inc.
121 Airport Drive
PO Box 1330
Watertown
SD 57201-6330
USA
+1 605 886 00 00
+1 605 882 00 00
Wurth Group of North America
93 Grant Street
PO Box 357
Ramsey, NJ 07446
USA
+1 201 818 88 77
+1 201 818 78 35
e-Mail: controlling@wurth-wugona.com
Holding Companies - International
Wurth Industry Network of North America
Office Maple Grove/USA
c/o Adams Nut & Bolt Co.
10100 85th Ave N
PO Box 207
Maple Grove, MN 55369-4586
USA
http://www.wurthindustry.com
Wurth Red Label
704 Morris Street
Charlotte, NC 28202
USA
+1 704 971 91 90
+1 704 377 24 11
http://www.wurthredlabel.com
Wurth Service Supply Inc.
4935 W. 86th Street
Indianapolis, Indiana 46268
USA
+1 317 704 10 00
+1 317 704 87 01
e-Mail: wurth@servicesupply.com
http://www.wurthservice.com
WURTH USA Inc.
Distribution Center Northeast
93 Grant Street
Ramsey, New Jersey 07446
USA
+1 201 825 27 10
+1 201 825 37 06
e-Mail: info-northeast@wurthusa.com
http://www.wurthusa.com
Wurth Wood Group Inc.
P.O. Box 668 005
4250 Golf Acres Drive
Charlotte, NC 28266-8005
USA
+1 704 394 23 38
+1 704 391 96 10
e-Mail: sales@wurthwoodgroup.com
http://www.wurthwoodgroup.com
Guest SuperSon
Whoa.Thats what I call a complete list -bounce- Im going to start calling a few monday . Thanks again Iron :beer:
Guest SuperSon
Thanks Red . :aok:
Tried calling them but I guess theyre close on weekend just like with everybody else.Monday I should know for sure
On my 5-door the rear are 12-1.25 and the third is 10-1.25 I found some at my local bolt store (fastenal) but they had to special order them and had to buy a box of each. 25 per box and they want about a buck a bolt. 50$ for 4 bolts that I need no thanks. Maybe if I can find enough others to go in on a buy in I would get them and send them out.
Guest SuperSon
If I dont find one from all the places above at a reasonable price Im gonna have to get the kit from ac. Im sure if the local bolt place here doesnt have them in stock they could order it also but like with you theyre gonna want me to order a box.
I just hate to have to order it from ac just for those 2 bolts but I need my truck to be another 3 inches up.
Guest SuperSon
Anyone doing a BL can save a few bucks by going with the 86-90 pathy BL kit granted that the rearmost bolt(M12X180) is available
The BL can be purchased on ebay for $90.95 shipped compared to ac thatll cost 150 shipped (quote was given to me a month ago)Thats almost $60 savings.
Those bolts according to you should only cost about a buck if you buy the whole box right? Lets say you sell them for $3-4 a piece . Im sure some would be interested specially a lot are doing BL and they can save atleast $40-60 going this route.
Oh yeah you did get a price for M12X180 right? Not sure if the 12-1.25 that you mentioned is the same.A lot of the places that I checked has M12 at 1.25 pitch but the longest they have is 100MM. :shrug:
