govols74n Posted March 27, 2007 Share Posted March 27, 2007 (edited) Ok, started this thread to show you guys how to use C.B. antenna mounts ($6.00 each from a truck stop) to mount lights on a safari rack or spare tire carrier. I still need to wire them up and paint them flat black. Light tabs are selling in some shops for $40.00 a piece. This is a cheap alternative, although a weld is best. Heres the CB mount You need to remove this part...just un twist Like this Install light like this. sly another What it looks like mounts on rack with 4 bolts, has grooves inside that grip to prevent slipping. Edited March 28, 2007 by govols74n Link to comment Share on other sites More sharing options...
sammyb33 Posted March 28, 2007 Share Posted March 28, 2007 that looks good. im surprised the 6x9s dont look HUGE Link to comment Share on other sites More sharing options...
mws Posted March 28, 2007 Share Posted March 28, 2007 Simple, easy, effective... What's not to like? A suggestion: Replace the nuts with nylon insert style, and then tighten just enough to hold in place during driving but not super tight. Then when you hit a branch (or a kamikaze bird), the brackets will be able to rotate and maybe prevent tearing off or otherwise destroying the light! Then your method becomes arguably BETTER than welded tabs... Link to comment Share on other sites More sharing options...
govols74n Posted March 28, 2007 Author Share Posted March 28, 2007 Simple, easy, effective... What's not to like? A suggestion: Replace the nuts with nylon insert style, and then tighten just enough to hold in place during driving but not super tight. Then when you hit a branch (or a kamikaze bird), the brackets will be able to rotate and maybe prevent tearing off or otherwise destroying the light! Then your method becomes arguably BETTER than welded tabs... good idea....thanx And, to me, the 6x9 lights do look HUGE, but I guess I will get used 2 them. Link to comment Share on other sites More sharing options...
Pezzy Posted March 28, 2007 Share Posted March 28, 2007 Cool idea! Link to comment Share on other sites More sharing options...
headpeace Posted March 28, 2007 Share Posted March 28, 2007 good idea, I like Link to comment Share on other sites More sharing options...
sammyb33 Posted March 28, 2007 Share Posted March 28, 2007 yea they look big, but i was expecting them to look bigger any smaller, and im not sure, but i think they would be too small. who knows...who cares, it works, it looks good, and bam, your good to go Link to comment Share on other sites More sharing options...
Pavelow Leaks Posted March 28, 2007 Share Posted March 28, 2007 Simple, easy, effective... What's not to like? A suggestion: Replace the nuts with nylon insert style, and then tighten just enough to hold in place during driving but not super tight. Then when you hit a branch (or a kamikaze bird), the brackets will be able to rotate and maybe prevent tearing off or otherwise destroying the light! Then your method becomes arguably BETTER than welded tabs... If you don't crank the adjustment bolt the light will swivel no matter how its mounted...but it does look good and I'm probly gonna use those to mount rear lights on my tire carrier. Good job! Link to comment Share on other sites More sharing options...
solid snake Posted March 28, 2007 Share Posted March 28, 2007 Yeah, I like cheap mods! Link to comment Share on other sites More sharing options...
Guest SuperSon Posted March 28, 2007 Share Posted March 28, 2007 Looks good gov. Itll even look better if you change those bolts to a stainless steel socket button head bolts :cool2: Link to comment Share on other sites More sharing options...
barthel Posted March 28, 2007 Share Posted March 28, 2007 Looks awesome govol!! Now the silly question, how or where do you take the wires into the cab? Link to comment Share on other sites More sharing options...
Harbinger Posted March 28, 2007 Share Posted March 28, 2007 Good idea! Link to comment Share on other sites More sharing options...
govols74n Posted March 28, 2007 Author Share Posted March 28, 2007 Looks awesome govol!! Now the silly question, how or where do you take the wires into the cab? Not a silly question at all, I do have the wiring harness, but haven't had time to run the wires yet. Most likely down the track on the stock roof rack to a door sill then on to the engine bay. I might look at it tonight. Not trying the moon/sun roof because then it might leak. Link to comment Share on other sites More sharing options...
sammyb33 Posted March 28, 2007 Share Posted March 28, 2007 drill some holes Link to comment Share on other sites More sharing options...
govols74n Posted March 28, 2007 Author Share Posted March 28, 2007 drill some holes No new holes in the roof....Already starting to worry about the sun roof seals lol. Link to comment Share on other sites More sharing options...
sammyb33 Posted March 28, 2007 Share Posted March 28, 2007 grommets and silicone goop are your friend Link to comment Share on other sites More sharing options...
Harbinger Posted March 29, 2007 Share Posted March 29, 2007 grommets and silicone goop are your friend My Pathy (back when I had her) just had a hole drilled through near the rise on the roof, near the passenger side door. Was only sealed with silicone, not pretty but effective. MUCH more effective than the 20 year old sunroof seals lol. Link to comment Share on other sites More sharing options...
govols74n Posted March 29, 2007 Author Share Posted March 29, 2007 No kidding....I'll take a look later this week and take more pics for the wiring. Have to mount the Westin lights I just got too. Link to comment Share on other sites More sharing options...
Harbinger Posted March 29, 2007 Share Posted March 29, 2007 I might add that silicone does start looking rather nasty after its been on a roof for a few years I scraped all the crap off and replaced with new before I sold my truck though. *sigh* all this talk about lights is making me 4x4 sick.....hmmmm, wonder what a light bar would look like on a VW sssh Link to comment Share on other sites More sharing options...
Extreme90path Posted March 29, 2007 Share Posted March 29, 2007 Awsome idea, I love it! I am going to use it for when I get a carrier. Link to comment Share on other sites More sharing options...
govols74n Posted April 1, 2007 Author Share Posted April 1, 2007 I might add that silicone does start looking rather nasty after its been on a roof for a few years I scraped all the crap off and replaced with new before I sold my truck though. *sigh* all this talk about lights is making me 4x4 sick.....hmmmm, wonder what a light bar would look like on a VW sssh You've got me thinking about breaking the drill out....might need to go buy that black silicine I found the other day....Hmm. Link to comment Share on other sites More sharing options...
RedPath88 Posted April 1, 2007 Share Posted April 1, 2007 If you take the time to look you could probably locate some grommets that, if done right would eliminate the need for silicone... or would reduce it to simply working as a gap filler and adhesive for the grommet. Link to comment Share on other sites More sharing options...
govols74n Posted April 1, 2007 Author Share Posted April 1, 2007 (edited) If you take the time to look you could probably locate some grommets that, if done right would eliminate the need for silicone... or would reduce it to simply working as a gap filler and adhesive for the grommet. Yes sir, that's what I plan on doing....2 rubber grommets/silicone to make me feel better/a drill/ wiring harness....beer Edited April 1, 2007 by govols74n Link to comment Share on other sites More sharing options...
sammyb33 Posted April 1, 2007 Share Posted April 1, 2007 yea i was meaning to use the silicone to seat the grommet, and then maybe a little from the inside to insure no water gets through Link to comment Share on other sites More sharing options...
LD50 Posted April 1, 2007 Share Posted April 1, 2007 Nice work I may have to do the same Link to comment Share on other sites More sharing options...
