mws Posted June 6, 2007 Share Posted June 6, 2007 Nope. It should be just fine.With the trans fluid flowing through that sucker at 40 psi, I highly doubt any "air pockets" will stay there long. Ford Exploder coolers are mounted with the input/outputs on the bottom. Stock. I REALLY doubt this idea. I did some experiments in Frankenvan, and I verified it did happen. I have the biggest B&M plate style in there, and the only place it fit nicely was having it with both fittings down. After a couple thousand miles, about 3/4 of it was full of air. To test, I started her cold and laid my hand on the cooler. After a few minutes, I could feel the bottom 1/4 or so warming up due to fluid in it, but the top did not. I drilled a hole in the top and installed a fitting with a plug. Fired up again, cracked the fitting and could hear air escaping. Replaced the plug with a new outlet fitting and plugged the old outlet. Link to comment Share on other sites More sharing options...
88pathoffroad Posted June 7, 2007 Share Posted June 7, 2007 You and your fancy-schmancy engineerin' degrees...you think you know what's goin' on! Allright, I stand corrected. *shrug* I'll check mine sometime and see how it warms up. Link to comment Share on other sites More sharing options...
WRL69 Posted June 8, 2007 Share Posted June 8, 2007 It is possible that installing the new coolers the capacity of cooling of the radiator is diminished? Regards, Any comment? Link to comment Share on other sites More sharing options...
Simon Posted June 8, 2007 Share Posted June 8, 2007 Shouldn't make any difference. The coolant, and tranny fluid run through separate flutes within the rad. If anything, not having to cool as much fluid (less heat radiating through it) should make it more efficient. Link to comment Share on other sites More sharing options...
Alkorahil Posted June 9, 2007 Share Posted June 9, 2007 Shouldn't make any difference. The coolant, and tranny fluid run through separate flutes within the rad. If anything, not having to cool as much fluid (less heat radiating through it) should make it more efficient. Yep Yep. Link to comment Share on other sites More sharing options...
leeuniverse Posted February 28, 2012 Share Posted February 28, 2012 If you are concerned about "cold" running with the Tranny or Engine, use "Lucas" or some other appropriate additive that provides a protective coating to the metals making things run more efficiently and less wear and tare cold or hot. Link to comment Share on other sites More sharing options...
