A key question, literally
radar
Ok, this will sound a bit weird, the area on my ignition key that is used to secure to a key ring has broken. What I want to do is drill a hole in the key so I can re-secure it to my key ring. My question is, will drilling the plastic area on the key damage it, I am under the impression that there is some sort of device in the key that is used to overcome the vehicle immobilization system, the vehicle is a 99 Pathfinder.
For my 02, the chip looks like it is located at the base of the plastic bit (where the metal comes out) so it is close to the reader.
Look at yours to see if that is the same. All the keys I have seen with chips have some sort of access hatch, then you will know about where it is if you have one.
