FUELER Posted November 15, 2006 Share Posted November 15, 2006 I have a VG33 in my 99. My oil level is below the "low line" on the dipstick when cold. It goes up and way above the "high line" when the motor is hot. I've never seen such a discrepancy in any other car. Which is an accurate indicator of oil level? Link to comment Share on other sites More sharing options...
vengeful Posted November 15, 2006 Share Posted November 15, 2006 What weight are you using? Link to comment Share on other sites More sharing options...
94extreme Posted November 15, 2006 Share Posted November 15, 2006 cold i check all my fluids cold. if they are below "low" then i add. i know that the manuals say to check AT and PS when hot but they fluids don't expand that much so i feel safer when checking them cold. Link to comment Share on other sites More sharing options...
XPLORx4 Posted November 15, 2006 Share Posted November 15, 2006 (edited) After reading a few sites about checking motor oil, most sites made no mention of engine temperature for motor oil check, but some said check it when it's hot. I couldn't find any sites that specifically recommended checking the oil level when it's cold. Click here for info From what I've read, it's more important to let the engine sit for a minute or two before checking the oil level so that most of the oil has had a chance to drain back into the sump. Edited November 15, 2006 by XPLORx4 Link to comment Share on other sites More sharing options...
FUELER Posted November 15, 2006 Author Share Posted November 15, 2006 What weight are you using? Mobil-1 5W-30 Link to comment Share on other sites More sharing options...
FUELER Posted November 15, 2006 Author Share Posted November 15, 2006 From what I've read, it's more important to let the engine sit for a minute or two before checking the oil level so that most of the oil has had a chance to drain back into the sump. Good idea, I haven't been doing that. I'll try again. Link to comment Share on other sites More sharing options...
Simon Posted November 15, 2006 Share Posted November 15, 2006 Yes....another thing, probably obvious, is to NOT check the oil when the engine is running. You can have almost no oil in the engine, and it will still show high on the dipstick if you do. Link to comment Share on other sites More sharing options...
