Guest SuperSon Posted October 27, 2006 Share Posted October 27, 2006 Howzit going guys Been doing some search again and I cant seem to find anything using the search option. Can someone please post a link on How to replace timing belt on a 93 pathy and how to on replacing fuel filter. I hate to be a pest guys but ive been here for almost an hour now searching for that how to with no luck :help: I have a haynes manual but id rather get ideas and instructions on how-tos from you guys.From what I heard haynes is not that accurate plus I dont think they know some of the tricks that you guys do. Link to comment Share on other sites More sharing options...
94extreme Posted October 27, 2006 Share Posted October 27, 2006 just look through the garage-->how to's. the search is funky and there are million references to t-belts here. lol be more creative with your "phrases" Link to comment Share on other sites More sharing options...
Casey.T Posted October 27, 2006 Share Posted October 27, 2006 Field Service Manaual... Chiltons or Haynes Manuals.... Or All 3 like me -bounce- Link to comment Share on other sites More sharing options...
RedPath88 Posted October 27, 2006 Share Posted October 27, 2006 how to on replacing fuel filter Are they welded in on a 93 or somthing... use the Haynes manaul... it is just fne for most things (like fuel filter replacement) It's about as easy as it can get... open the book Link to comment Share on other sites More sharing options...
88pathoffroad Posted October 27, 2006 Share Posted October 27, 2006 The fuel filter is easy as pie, it's right under the hood on the passenger's side. Unclamp, pull hoses off, replace, re-clamp. Oh, pull your fuel pump fuse, then start it and let it run till it dies first, that'll relieve the fuel pressure in the lines and filter. The t-belt write-up...man oh man. Mechman2K and I did a complete write-up on my old forums with pictures of everything and then it got hacked, so it's gone...try searching the web for the 300ZX crowd's coverage of how to change the belt for a VG30E. Same engine, same thing for the VG30i as well. Link to comment Share on other sites More sharing options...
thatguy03 Posted November 7, 2006 Share Posted November 7, 2006 http://www.jimbennett.net/timing_belt_replacement.htm here is a link i found in my bookmarks hope it helps Link to comment Share on other sites More sharing options...
jj big shoe Posted November 7, 2006 Share Posted November 7, 2006 Here's one from Datz510 on N4W. Take your time and you should be fine. If you have a question once you've gotten into it I'm sure you'll get a quick response from the board. Good luck. Link to comment Share on other sites More sharing options...
