FLApathy Posted September 29, 2006 Share Posted September 29, 2006 (edited) So I just got done with the motor swap, went to pull it out of the garage, reverse, nothing, drive, nothing, 1st and 2nd, nothing, the tranny cant be toast yet, it appears that it was replaced at a 97k and I have 162 on it now, ive had a tranny cooler since the day I got it. The torque converter is hooked up the tranny is moving fluid and its full up on that. But the good news is the motor runs like a dream and I now have an e-fan. and in other news, im an idiot and put this in the wrong forum, and i cant spell Edited September 29, 2006 by FLApathy Link to comment Share on other sites More sharing options...
GrimGreg Posted September 29, 2006 Share Posted September 29, 2006 T-case in neutral? Did you hook the driveshaft back up? Link to comment Share on other sites More sharing options...
FLApathy Posted September 29, 2006 Author Share Posted September 29, 2006 Checked the case, tried it every setting, never unhooked the rear shaft. Link to comment Share on other sites More sharing options...
unccpathfinder Posted September 29, 2006 Share Posted September 29, 2006 did u accidently unhook the shift cable...or r u a manual...if so did u have to unhook the slave cylinder and forget to put it back on the tranny? Link to comment Share on other sites More sharing options...
FLApathy Posted September 29, 2006 Author Share Posted September 29, 2006 Its an auto, the connections all work, I saw them move with a buddy moving the shfiter from inside. Link to comment Share on other sites More sharing options...
Casey.T Posted September 29, 2006 Share Posted September 29, 2006 (edited) Did you put the 4 bolts in that connect the flywheel to the torque converter???? Hehe, I read it, just double checking... Edited September 29, 2006 by Casey.T Link to comment Share on other sites More sharing options...
mws Posted September 29, 2006 Share Posted September 29, 2006 Is the trans the same as was in there before, or did it come with new engine? Could be something as easy as the torque converter had drained itself and is taking a while to refill. Double check fluid to see if it dropped a bunch as the TC filled up. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 30, 2006 Share Posted September 30, 2006 I second the fluid level check. Run it through the gears one at a time with the engine running as well to ensure that fluid flows through all circuits inside the valvebody and lines. Filling it once is the first step, you gotta run it through the gears and re-check after that to be sure it's full. Link to comment Share on other sites More sharing options...
FLApathy Posted September 30, 2006 Author Share Posted September 30, 2006 the pump is gone, no fluid at all coming out of the tranny lines, in any gear at any RPM. Link to comment Share on other sites More sharing options...
88pathoffroad Posted September 30, 2006 Share Posted September 30, 2006 Crappeh. Link to comment Share on other sites More sharing options...
Pathfinder Phil Posted September 30, 2006 Share Posted September 30, 2006 the pump is gone, no fluid at all coming out of the tranny lines, in any gear at any RPM. Are you SURE the TC is engaging the pump? If you ever pulled the TC off the tranny, it's possible. Also, did you fill the TC with fluid? Is the pump cavitating? Anything like that? Just putting out possibilities to try. Usually free to try stuff, trannys cost money. Just trying to help! Link to comment Share on other sites More sharing options...
FLApathy Posted October 1, 2006 Author Share Posted October 1, 2006 Apperantly the Mazda MPV used the same tranny, my dad works at Mazda and there happens to be a guy who rebuilds them there too, and my dad knows the people they take their cars to for that kinda work, talk about a lucky break. And Phil, when I started the motor for the first time, we forgot to hook the tranny lines up, kinda shot fluid all over my driveway, so we unhooked them again and got nothing. Link to comment Share on other sites More sharing options...
