trashman Posted September 28, 2006 Share Posted September 28, 2006 Remmeber i'm a newbie ,,just bought a 99 R50 3.3 its got 28k miles on her (actual ) do you guys think i need to replace the timing belt because of its age ? this site has convinced me that this is a weakpoint that will coast mucho to repair if it slings.. Link to comment Share on other sites More sharing options...
vengeful Posted September 28, 2006 Share Posted September 28, 2006 No. It's fine. I replaced mine in my 99 at 102k, and it still looked pretty dern new. Link to comment Share on other sites More sharing options...
XPLORx4 Posted September 28, 2006 Share Posted September 28, 2006 28K is awfully low for a 7-year-old. It was either not driven very frequently or it was driven frequently on low-mileage trips. The latter is by far much worse than the former. Are there any maintenance records? Hopefully the oil was changed regularly at 3,000 mile intervals. Are there any seals or gaskets leaking? How's the battery? Brake fluid? Coolant? Link to comment Share on other sites More sharing options...
mws Posted September 28, 2006 Share Posted September 28, 2006 No, unless: - It had a water pump or oil leak that dumped fluids on the belt. - It was stored in a garage with a freon compressor running in it (refrigerator, freezer, air conditioner, etc). Freon compressor generate ozone, which attacks rubber. Does it still have original factory tires? If so, do they show any signs of cracking or checking? If not, then they were not exposed to much ozone, so the belt wasn't, either. And how do the accessory drive belts look? Again, if they look to be in great shape, you can assume the timing belt will be the same. But if they are severely glazed and cracked, the belt may be more in question. Link to comment Share on other sites More sharing options...
vengeful Posted September 28, 2006 Share Posted September 28, 2006 IIRC, he bought it from some guy who "thought he needed it" and pretty much only used it on trips to Aspen/Vail. Check this thread for more information. Link to comment Share on other sites More sharing options...
94extreme Posted September 28, 2006 Share Posted September 28, 2006 i wouldn't sweat it at all unless you have any issues mentioned above and then you just might as well.. otherwise.. forgetaboutit Link to comment Share on other sites More sharing options...
Casey.T Posted September 28, 2006 Share Posted September 28, 2006 There is nothing that says you cant open up that top cover and see what she looks like..... Link to comment Share on other sites More sharing options...
