Hormonic Balancer...
SaKaNa
Why is the rubber from mine just GONE? All the @!*% spins freely now! I couldnt figure out what that horrible metal-on-metal sound was, so I used belt conditioner to fix "that squeeky belt"... turns out it made it significantly worse. In the words of my mechanic "I'm actually pretty suprised its been running for a few weeks like that"...
WTF its expensive! THe part alone is like $250 or some @!*%.
If your getting your timing belt done you might want to consider looking into getting your water pump, timing belt tensioner,thermostat and coolant bypass hose done too. And you should atleast have him look at your cam-seals and your crank seal while he has it all apart too. It may be a little more money but better than getting that work done then having to spend mucho $$ just down the road to do it all over again.
