big_johnson
Everything posted by big_johnson
  1. Mt. Antero...Buena Vista...sweet I took my pathy up that trail this summer, I love that area. As for the Pathfinder, the rear axle is actually quite strong, better than the axles in the wrangler. However, the IFS on the pathy won't hold up to quite as much. You could put a one or two inch lift (more lifts coming out sometime here), and run 31's or 32's. As for what to look for, the shocks, struts, and bushings may need replacement (or will soon). The exhaust manifolds may leak, but the problem isn't as big as on the 95's and earlier. There's some more potential issues, but I'm sure someone else will chime in
  2. Not to mention the IRS, even though several reports commended it on its offroad capabilities
  3. You do realize those posts are over three years old, right? Stillen no longer makes headers for the VG33E. However, apparently the VG30 uses the same block as the VG33, and the thorley headers will technically fit on the 3.3. However, the cats/etc. will not be the same, and getting street legality would likely be a hassle.
  4. Might want to check out Dynomax also. Myself and a few other R50 guys are running them, I personally think they sound sweet. Probably not as loud/growly as a flowmaster, but has a nice rumble to it when you get on it (not ricey at all, BTW). I also love the sound of my exhaust in low range, it's bada$$
  5. Please don't. They make me want to :oops: or
  6. Check the bottom of the 3rd page in my cardomain site (in my sig). It has a few old pics of my pathy sans brush guard but with the bug guard
  7. These are pretty much like running boards than you can beat the he11 out of. If you like the chrome look or something like that, then these probably wouldn't be the best for you. But if you need something strong, functional, and good looking, then look no further
  8. yep. We'll work with your example, 235/75R15 the first number, 235, is the tire's width in mm. There are 25.4 mm in one inch. So, 235 / 25.4 = 9.25 inches in width. The second number is the aspect ratio (ratio of sidewall height to width). In this case, the sidewall is 75% as tall as the tire is wide. So, 235 x .75 = 176.25 Multiply this by two (since there is a sidewall on either side of the rim). 176.25 x 2 = 352.5 mm total sidewall height Then figure out the rim's diameter in mm. 15 x 25.4 = 381 mm 381 + 352.5 = 733.5 mm is the total tire height 733.5 / 25.4 = 28.88 inches in total tire height
  9. I was thinking about this a while ago. Since the LE WD21's came with discs, it seems to me that it would be a good idea to find one of those H233B axles and swap it in. However, I don't know if the linkages would be the same, and I'm not sure you could get the ABS to work. But, the older axle would also give you a greater selection for lockers if you decide to go that route, also. I haven't done much research into the swap, but it seems like it would be a viable option
  10. Extra wear on the CV joints, this is why most people w/lifts get manual hubs. The taller springs put the CV's at an extreme angle and make them much more prone to tearing/grenading. The struts also top out more frequently, but I haven't heard anyone complain about premature strut failure because of this.
  11. I offroad a fair amount with mine on, but if I had to do it over again, I probably wouldn't get one. I originally wanted one because they looked cool, and I didn't know much about 4wheeling. My main gripe is that it hurts the approach angle a fair amount. Also, like you suggested, it is not strong enough to hold up well to a hit, so it could derfinitely cave in to the hood or front area and cause more damage than would have been caused w/o one. However, I still think it looks cool, and it does actually help protect the headlights from rocks/trees etc. A bulll bar, on the other hand, is meant to withstand hits and not cause damage to the vehicle. They are strong enough to mount a winch on (another thing the brush guard can't do), and also have mounting holes for lights. Like you said though, they are pricey.
  12. I did not have to remove mine, but I beleive that the brush guard shares some of the mounting holes that the tow hooks use.
  13. the LE's have the same bolt pattern as every other Nissan (except for the titan and other brand new ones). It's just a matter of what size the rim is. A 16" will work, a 15" will be too close to the caliper on an 02. Since you have an LE, you have the 17" rims, right? In which case, the pro comps won't fit unless they're made for that rim diameter (I doubt it).
  14. Why don't you like air lockers? Get some of those front and rear, your 4wd system would work much better than the JGC's, and wouldn't have all the electronics to add to the possibility of a system failure
  15. I used mesh like DJ, but with a circular hole cut out that hooks to a flex pipe which runs to the underhood airbox. I have a picture and a description of it somewhere in my cardomain page, the link in my sig
  16. A guy over on AC's board has been working on a design and other possibilities for an R50 sas, but it would be a huge, costly project. We don't have a real "frame" to work with, we just have the unibody and a sort of "subframe" for the front end.
  17. So you're combining the springs with spacers up front? Won't that put the CV's at an extreme angle? I think you'll be OK with 3/4", but I'm not sure about 1 1/2".
  18. Exactly, thats why they will tell you anything
  19. Assuming he has the same hitch as me, just check the link in my sig, then go to page 2. I have a few pics where you can see the hitch
  20. From what I've seen, my hidden hitch doesn't look like the factory Nissan hitches. However, they could have made a different model for Nissan to use as OEM. I thought I read that Draw-tite makes the OEM hitches, but I could also be wrong.
  21. I would guess that to order the kit and somehow import it, the cost would be well over $1200 US. Don't know for sure though. Why not wait for L&P? $995 for the 6", $750 for the 3".
  22. Well its not technically "out" yet, they're still finalizing the product, and have had to deal with some personal issues along the way. Should be out relatively soon, though. Here's the page L&P Performance
  23. From what I've seen, the OEM ones stick the closest to the bumper and hurt the departure angle the least, but I'm sure there are other brands that make an OEM identical hitch, though I don't know what they are off the top of my head. I have a Class III Hidden Hitch on my 97 and it sticks out a bit far. Looks good though, and will teach whoever rearends me a good lesson
  24. On the XE's and LE's, the gearing is 4.363:1. The SE's had 4.636's in the axles because of the larger tires that came stock. The latter would be good for 31's, but it wouldn't be worth the hassle of regearing for such a small tire change. Now if you eventually got a big L&P lift and threw 33's on there, you'd want to regear, but with just 31's you should be OK with the 4.363's
  25. I have a class III Hidden Hitch (which isn't so hidden) and it works well. Uhaul has some nice ones also, though they are just another brand (draw-tite?) rebadged w/uhaul stickers. You can put manual hubs on your LE, search a bit for more info, there have been some recent threads on the subject. I have a Manik brush guard on mine, I like it. I would recommend that you go for a one-piece design, as opposed to modular, but it's all personal preference w/grille guards.
