Everything posted by madhatter_xe
The Kumho MT's are a great tire. I don't have much experience with other tires but these have held up great and the tread really digs in. If you live in an area with long winters, I would recommend getting them siped for traction on ice though. This is a good review: KUMHO
Yup, just got er off. what a friggin weekend, did the valve cover gaskets yesterday only to find the leak get worse. looks like its the crank seal but oil sprayed everywhere so i should probably check the cams too. Thanks.
Hey, does the crank sprocket just pull straight off? any tips on how to get the thing off? Edit: Also, do you need to pull the oil pump to change the crank seal?..god i hope not.
Good call 88, the wax choke is sticking. I don't need high idle for the summer, so until I have time to fix it, I just tied it back with some wire...works great now. Cheers.
That one with the pistol grip looks like an AK-47, minus the huge clip hanging down.
Can you clarify your question. So you have a new RADIATOR and you want to hook up an oil filter relocation kit. Did you say you want to T it off and run the tranny and engine oil through the relocated filter?
length/height
Yeah, thats where I ended up putting mine too. I don't have an E-fan, but haven't had any issues. *knock knock*
I couldn't get mine to fit on the front of the condenser no matter what I tried, but if you can, its the best spot for keepin it cool. You can use vice grips to clamp the lines before disconnecting them too, makes it a cleaner job.
Should my MAF sensor have been dirty?
madhatter_xe replied to zack1978's topic in 90-95 WD21 Pathfinders
My '88 has nearly 300K KM's on it and the MAF wasn't dirty at all, but it doesn't hurt to wipe it down just in case. -
Can you folks hunt with handguns down there? We can't in Canada but I've always thought it'd be a blast.....literally.
Thanks for all the info. I used some intake cleaner on it lastnight and sprayed everything off, I think it dropped the fast idle about 100 rpm's. The butterfly was surprisingly clean and shiney on both sides. I'll check out the wax choke tonight b/c it still doesn't kick down off fast idle. Cheers
That thread is gold. Cheers
thanks Fueler. My pops mentioned the fast idle valve, but my truck seems like its really screaming....louder than normal. Maybe i'll toss in some STP or something.
Not sure. How would I check that, clean the TBI? EDIT: Thanks for the heads-up Slick, where is the charcoal canister and how do you adjust the throttle? I'm not sure I want to adjust the throttle b/c it eventually idles properly at 7-900rpm's.
Hey Slick, Yeah, i cleaned the MAF a couple months ago and have checked for a vaccum leak. i'll take a closer look tonight as i change the valve cover gaskets.
I tried the "search" function but couldn't find much for useful info. My truck has been revving high for a few months, I thought it was b/c of the cold weather, but it isn't cold anymore and it continues to rev at about 2K rpm's until I drop in into gear or its been running for a while. After its been driven and is warmed up it idle's fine at about 700-900 rpm's. The engine doesn't sound good when it rev's up around 2K rpm's, Is this a sign of a worn out engine? :confused: Thanks for any info.
Sounds like the alternator is hooped. Before going out and replacing it you could get it tested, it might just be a bad diode, or stator, or regulator or something. Might be cheaper to rebuild it.
hey delavoie, what happenned to the pics?
That thing must haul arse. I think I saw your post on nissanoffroad too, cost something like $13,000?!
I asked about the lift. Here is his answer: From the sounds of it, the blocks could turn, unless he has two bolts through them.
I couldn't get the tensioner off the bar so i found it was a lot easier to just loosen the front bolts on the lower control arm and slide the T-bar back and rotate it. But some folks have done the other way too. Be sure to mark the bar though so you rotate each bar the same amount. Good luck.
Is the PSPS that necessary? Does it just increase the RPM's so you can pump more PS fluid when your truck isn't moving? like in a parking lot. Or will it actually affect how your truck runs? my truck is still running fine, it rev's high(2000rpm's) in park and neutral and obviously doesn't turn as well when stopped. But other than that i haven't noticed much difference. I'm hoping the PSPS will bring my idle back to normal when in Park...but who knows. that could be anything.
That isn't really an option..fraid my "ladies" just aren't big enough And they'll be mailiing the part to me. Yeah, thats what I told'em, it is complete BS. I think they're just too damn lazy to put the PSPS in the mail.
