16
Cuong Nguyen last won the day on January 18 2020
Cuong Nguyen had the most liked content!
About Cuong Nguyen
- Birthday 11/16/1983
Shelly 93 Pathfinder 4wd converted
Skilled/Experienced Mechanic
30-35
XE
1993
Contact Methods
Website URL
http://members.cardomain.com/cuongnguyen
Gender
Houston, TX
Country
Interests
My Pathfinder and helping others.
9,917 profile views
Cuong Nguyen's Achievements
NPORA Old-Timer (5/5)
222
Thanks everyone!
Feeling a bit motivated this year in tackling my long haunting no start issue and I suspect it's the damn factory alarm giving me crap. How the hell do I do it LOL.
Dashboard lights Brake and Battery
Cuong Nguyen replied to PamPoovey's topic in 96-2004 R50 Pathfinders
That's code for alternator going out. Probably the voltage regulator or whatever. It's a hit and miss with remanufactured alternators. I cannot offer any tips or advice since I've never worked on an 02 model other than unplugging the battery first lol. -
It's held in place by a woodruff key like the crank pulley. I'm figuring you already have the belt off and what not so you can spray it with some penetrating lubricant and some light taps should work it loose....or wedge something behind it and leverage it out a bit. It's been a while since I've done it...
Fuel Pump Replacement Suggestions?
Cuong Nguyen replied to dmvhornback's topic in 90-95 WD21 Pathfinders
You sure that pump is bad? How do you know your pump is bad? Did you test it to see if the pump is actually getting power ans actually pumping out fuel? Yoi can disconnect the fuel line feeding to the fuel rail to make sure it's pumping.. the pump should prime for a few seconds when you turn your ignition on ans you should hear your pump click on. I'm using a cheap pump off Ebay for 60 dollars. So far so good. Sent from my SM-N960U1 using Tapatalk- 15 replies
It could be the ignition switch going bad. You could hot wire it or bypass it to see. I'd check your connections to make sure they're not loose or corroded. Check the voltages too as well as the starter relay.. I had the same issues and replaced the ignition switch and so far no problems. Sent from my SM-N960U1 using Tapatalk
Pressurized Fuel Injection Cleaning 97 Pathfinder
Cuong Nguyen replied to AR97Pathfinder's topic in The Garage
Curious, what is your mileage on the truck? Sent from my SM-N960U1 using Tapatalk -
Thanks for the laugh this morning! Sent from my SM-N960U1 using Tapatalk
It was cheaper to just by a new maxima alternator 90A. Bolts right up after you swap out the pulley. I had to file down the OE pulley for clearance (YMMV). Easy 20A upgrade. I still need to upgrade the wiring as it's not cutting it for the occasional winching.
Intermittent issue - sounds like a vacuum leak?
Cuong Nguyen replied to willaay's topic in The Garage
Hahaha. That surging is all too familiar with me. I deal with it on a weekly basis. The later models (94/95) came out with a TSB where they added a pigtail with an external ground to the MAF harness plug to the sensor. Poor ground or corrosion/connectivity will cause that idle surge and stalling when rolling to a stop. -
This is done with the engine running? I have really not heard of this. What I have heard done was having the injectors cleaned and flow tested (I've done this) and most folks replace faulty ones as needed/indicated. -
Damn. That's a lot of oil. Have you figured out the source?
Edit: crossed the fuel hoses at the pump.. all good now other that the sputtering and missing. Guessing from the bad fuel.. Truck won't start. Fuel related. I prematurely thought it was my junkyard pump going out since my tank is slight rusty. Pulled the pump to see that the pre-filter broke off. Swapped in a new pump and nada. So assumed that the fuel filter is clogged. Pulled the filter and it was dry. Disconnected the line and placed it in a bottle and primed the pump. I hear it prime but nothing is coming out... I'm sure I connected fuel lines back correctly. What am I missing? I turn the ignition on, I hear pump prime and stop. Turn off the key and I hear a click from a relay seconds later.
You can try a bolt extractor for rounded heads or weld an open end wrench to it.
