Nismojunky
Everything posted by Nismojunky
No Dash lights? dimmer switch bypass?
Nismojunky replied to fishodeath's topic in 90-95 WD21 Pathfinders
Sounds like the dimmer switch there pretty cheap check the FS section look for someone parting out a pathy and get it from them cheers hope that helps -
exactly
your inclometer will fit under the radio on the 95 thats where i have mine im sure i have a pic somewhere
most of your parts are inner changeable y not swap everything to the 95? and keep that?
the o rings on your injector are shot causing the gas to leak in Mr.Jim had this problem maybe he will chime in, try searching for his post
fiberglass patch and bondo would be ur best bet
thats what i was afraid of
thats what ive been doing for a year now, the problem is im a contractor and i have lunch in my truck and its friggen cold right now and 3 isnt moving enough heat into the cab (im a smoker window is cracked)
hmm wheres this switch
Where's the resister pack for the blower motor mine doesn't work on 4
love winter driving like my1path said pulling 2wd trucks out is a blast
this is news to me ive set up a few dual altys in trucks one being a blazer never had any problems please ex-plane how it will fry everything?
your heater hoses or core might be pluged pull them off and blow compressed air threw them
SAS Parts vendors
Nismojunky replied to RedneckDave's topic in Solid Axle Swaps, Hardcore Custom Fab
http://completeoffroad.com/ most of your gearing needs and axle needs plus custom drag links and pretty much everything u need for the axle -
tape a spare key some where problem solved
i have a 140A military alty coming and i brand new reman 90A i want to run both with the sound system thats going to be installed im going to need it plus with all the lights and winch i plan on having the extra juice will be needed
i need some help im going to be running dual battery's i also want to run dual altys, what i want to do it have both altys charge the main battery and transfer power to the rear battery i want the rear battery isolated how can i do this most idolaters ive found or looked at said not to use the rear battery as a power source just as a backup for starting , i want to run my subs inverter and oba off the rear battery how can i do this?
creekkid send me a list of parts u need ill check my parts truck u cover shipping and ill ship it out to u
im with him when me and the girl friend go out for dinner we try to go to these "mom and pop" places, good food not premade crap, its better for you and most of the time it costs about the same. Second I only buy top grade stuff whether its tools truck parts ect if you cheap out once your buying again. Sourcing products that arntt made in china is getting harder and harder, ill buy local when ever i can i hate these big box stores. Just last week i put a sound system in my coworkers truck, he came over looked the truck over and went to FM audio and Video (its a local store that sell tv's car audio that stuff) when we were in there he said o future shop has something like that half the price of that one so i got my buddie who works there to explane the differences with everything, to make a long story short we ended buying most of the stuff at furtue shop, hes complaning about the sound quality and wishs he bought the better product in the first place.
Mudflaps for winter, with 31"X10.5"'s
Nismojunky replied to Eviltwin's topic in 90-95 WD21 Pathfinders
cut a peice of rubber and a couple of zip ties should do the trick -
mine have been on for 2 years no problems
yea we did that that was more expensive then the rms
dont know the size couldnt you go to a pick and pull wreckers by u and get a set? dealer ship is also an option
