alexg89
Everything posted by alexg89
  1. well the Vg33 whether its in the pathy, frontier, or Xterra, seem to be a common issue. Ive put a handfull in my 01 xterra. worth sourcing one and trying out. I keep a spare in the back lol
  2. i bought these same ones years back. Hit the tip of that center section with a flapper wheel and knocked it back a little. used the stock cclip and all was well
  3. id slap the tank a few times with a mallet and see if you can jar the pump. had to do this before and it at least got me home
  4. im getting ready to pull the trigger on one and id like to know what im getting into. Doing it i dont believe will be an issue, but for something ive never tackled im sure its going to start off rough. Any one have pictures or a link of an install? trying to search up on the site but havent really come across anything helpful
  5. i always get rid of the spider web of stuff under the intake. my fix are these large thick vacuum caps you can get at a local part store. Been running my woods truck like this and just did the r50 i got. unfortunately in this picture you can see where i left my hose clamp off on the heater hose lol ' https://imgur.com/a/5rEE8mI
  6. it was number 2 intake, 1 exhaust, and 3 intake and exhaust. and i hate to say this.......... i stuck them right back in lol. Motor was a gamble to begin with considering milage, blow head gasket and the fact cylinder 2 and 6 had some bad pitting in the cylinders. This motor isnt long for this world and i dont expect it to be. Just trying to keep it running long enough to actually build the truck and then im gonna be souring a lower milage one and spruce it up a little. Ive got an extra supercharger for my xterra ill probably end up stuffing under the hood at that point also
  7. I'll give it a read my man! Worst case I Sas this one too hahha
  8. I appreciate the open arms! lol talk to me about this reverse cut stuff. ive never really understood it. As for the differential itself, whats limiting me to sticking an xterra full front diff in place of this one?
  9. Scored this little 96 about 3 weeks ago. guy said it had an overheating problem with 223k on the dash. Drove 3 hours to check it out and it looked promising so i got it. 5speed 4wd, clean interior, not alot of rust thank goodness. But come to find out the headgasket had pushed out on cylinder 4 so tore it all apart. Upon having it all tore down cylinder 2 and 6 had some pitting in the cylinder, so took a 3 stone hone to it and tried to clean it up the best i could. few lifters were a little beat up but we are gonna run it as is. Get it all back together, and it fired right up. Throttle had a bit of a hesitaton when you blipped it but ran fine when you barley got into the throttle. Come to find out MAF was no good. Stuck one in from my Xterra and she runs just fine. Unfortuently the trans may be bad, gotta get it out and check the counter shaft bearing in the front, being its howling pretty bad on de-celeration. worst case i source a wd21 trans since the gearing is better. Plans are to source a SFD and get some 33s or 34s under it. Question, being a 96 is this thing 31 spline or 33? cause id like to get some 4.9s in this thing also Anywho lets see how this thing goes https://imgur.com/a/BbKLrpJ
  10. got it on. only thing we used from the Xterra was the supercharger, intake, lower intake, and pulley bridge. Stock ecu, stock crank pulley, stock injectors, stock maf. got a 69.5in 6 rib belt, cut 1 rib off to fit the 5 groove crank pulley and ac compressor. fits like a dream. Notched a half hole on the top right bolt for the tensioner bracket since it was off half a hole and pinched it tight with the bolt. cut the hood and we are good to go. Gonna hook up a sniffer to it to see what AFRs are looking like but with headers no cats and full 2.5in exhaust we are still getting some black smoke so dont think its leaning out. moved knock sensor up to the top of the sc but i think it may be pulling timing when it hears some stuff. gonna get it on a scanner and see whats happening there also, may stick a resistor in place. good bit of teflon was missing so we are seeing just a smidge above 5lbs on the boost gauge, we got a buddy who does cerakoteing and other engine assembly coatings which are safe for the sc rotors so we may rebuild it and get them coated. Other wise it runs great and zero issues so far
  11. im sure its possible, do we want to go to that extent though? not really. i got majority of all the parts cleaned up at work so far and i think we may shoot for this weekend to stick it all together. guy we got it from didnt really have all the bolts so thats gonna be fun. but ill keep this updated as we go. stock ecu and stock injectors should be fine since these things have a pretty fat fuel map as it is. plus we have a boost reference FPR worst case
  12. good deal. ive been trying to find someone who has attempted it. Commented on one of his videos to see if hes still around. Curous to know if its still kicking. Running na ecu and injectors may be Risky but unplugged o2s would give he extra fuel. question questions questions lol
  13. Lets talk SC stuff. Im familiar enough with it being i swapped my 00 xterra. Buddy has a 97 that is SAS and hes diggin the SC swap i did. I have a spare xterra motor with all the bracketry so we can get the alternator and ps pump swapped to the correct sides if need be but i dont see that being an issue. What i do see being an issue is that the ECUs have a different pigtail. which doesnt allow me to plug an play the xterra ecu into the r50. This brings me to my next thing. option A, stock ecu, stock injectors, Xterra maf, wide band and see whats going on. option B, stock ecu, SC injectors, z32 or maxima maf, wide band, ect Option C stock ecu, stock injectors, Boost reference FPR, wideband ECT. We had a rear mount turbo R50 once with just the FPR and it ran great on 7-10lbs. Never blew up, never hesitated, and made good liniar power. Ive searched all over the web for a SC swapped vg R50. Give me some light if you have it casue if not we are moving forward anyway with trial an error
  14. i got it off etsy, its for a toyota highlander . i cut it to fit
  15. Scored some 31x10.5 mts on wheels for 70 bucks and stuck some 7in leds on the bush guard
  16. so after probing everything, burping the system multiple times, getting a mechanical temp sender, pressure testing the system, hooking my scanner to it ... come to find out its the dash gauge itself.. i punched the dash and it started working again.. took the dash apart cleaned everything up .. took the gauge out of the cluster cleaned the contacts and printed board, re tighten it all back up and it works fine
  17. So let it warm up again, bought a mechanical Bosch gauge from advance.. popped the radiator cap off, turned the ac on and let it idle for 20-30 mins and it maintained 185-190... hold it at 1500-2000 and it would drop a little from circulation.. im thinking either there is a wire issue or the temp sender is bad but i already replaced it with another one off an old motor.. ordered up a new one and we will see what happens
  18. So check this out.. im wondering if a wire got pulled somewhere.. Not saying the cooling issue isnt there but its never ran hot before ever I go out and was gonna move it up the drive way and i notice the temp gauge is up a little bit.. its 67 degrees here in central fl and it hasnt moved since last night
  19. Drained it made sure everything flows.. same thing.. top hose is hot.. bottom is kinda warm.. im thinking thermostat
  20. So check this Pulled up in front of a buddys, put it in low range, did a 2wd 1,2,3 smokey burnout.. got down the road and it was running hot.. get home and the upper hose had slid off just enough to leak.. Put it back on and weirdly enough it wasnt low on coolant.. let it idle in the drive way and the temp gauge just goes up to H.. Bleed the system with the bleeder on the intake manifold and its good. switched out the temp sensor on the upper outlet .. same thing Been sitting in the driveway for 30minutes now and its still up on H.. thinking maybe thermostat is stuck? top hose is hot lower is kinda warm any ideas??
  21. Got some paint on the wheels this weekend. Was gonna put my manual hubs and snorkel on but lacked motivation
