Dozzerwd21
Everything posted by Dozzerwd21
  1. What's a timing light like that inovva one cost? Sent from my Z982 using Tapatalk
  2. Not familiar with either model but welcome. Sent from my Z982 using Tapatalk
  3. There's factory service manual downloads available on here that give you detailed instructions on how to change your timing belt . Just get your crank tdc and your rotor should be on the plug #1 iirc Sent from my Z982 using Tapatalk
  4. Or hid with ballast attached to your factory wiring I hear works . Sent from my Z982 using Tapatalk
  5. Try them in my experience HiD over LEDs anyday Sent from my Z982 using Tapatalk
  6. Bro I double and triple checked mine and I still hear a whistling noise the one that made mine sound like it was going to die was the one that runs behind the engine from somewhere and into the cruise control in the left corner of the engine bay be sure not to get confused and think it's going to the trans relief line in the firewal behind the cruise control Sent from my Z982 using Tapatalk
  7. Do you have the OEM part #? Sent from my Z982 using Tapatalk
  8. After noticing hesitation on acceleration I asked a member what u should try he suggested cleaning my maf sensor and this is what I went with. Results being smother acceleration. Sent from my Z982 using Tapatalk
  9. Nevermind just tried something Sent from my Z982 using Tapatalk
  10. Just got the app and new to it how would you post a pic? Sent from my Z982 using Tapatalk
  11. Vacuum line somewhere torn or a hole in one? Sent from my Z982 using Tapatalk
  12. Did it work the light sensor adjustment? Sent from my Z982 using Tapatalk
  13. Try checking your tps and try cleaning your maf sensor and basics distributor plugs wires vacuum lines too Sent from my Z982 using Tapatalk
  14. Last time I got in mine I discovered a middle seatbelt I thought it was only two seatbelts. Sent from my Z982 using Tapatalk
  15. Somebody find one mold it and sell me one please! Sent from my Z982 using Tapatalk
  16. I'm changing the bushings on mine for that reason also my brake caliper seems to be sticking on the top piston. Sent from my Z982 using Tapatalk
  17. Rear little window hinge . Or rear hatch window hinges?
  18. I thought it was mounted on top too
  19. Has anybody tried just a universal coil spring spacer for the rear?
  20. https://drive.google.com/file/d/1-AyDbVhaeRB1--ylk62IcVkDlbsoxFO6/view?usp=drivesdk
  21. https://drive.google.com/file/d/1--auK9iu8pc77j0sh74Le1A8RQ-rcT9a/view?usp=drivesdk
  22. Finally got it complete! Spare tire carrier installed back awhile back setting the project on the back burner. Well 2 weeks ago I finally got a spare rim 15x8 unfortunately white. The tire cost me more than the rim but finally got it all together.
  23. So strut bar, tension bar, and one I can't remember . Either way it's mash on my suspension. Along with sway bar links . ordered the parts and should be coming in the mail Sunday.
