13
Everything posted by joshrichard
I’m know this has been discussed, and i’ve seen people do it, but would like input from those who have done it before. Is there anyway to add the 1 inch spacer without taking the entire strut apart? I know the lip of the top perch restricts removal of the old bolts, but what if you were to cut the old bolts in half then put the new hardware through the top? Would it be worth the trouble? i know both ways have their own difficulties. The only person i can think of who has done the OME spring with spacer off the top of my head is @02_Pathy
I was getting the code, and ended up just relocating it because it’s a PITA for just a sensor Sent from my iPhone using Tapatalk
yeah me too, that link doesn’t work Tyler. At least not on mobile Sent from my iPhone using Tapatalk
AFAIK the only option for the rear locker is going to be an ARB air locker. Not 100% sure though, maybe someone else can chime in. Sent from my iPhone using Tapatalk
I really liked Micahs bumper. he integrated the hitch into his custom bumper. It helps if you ever drop onto the rear as well. Sent from my iPhone using Tapatalk
If you get a locker in the back, you’ll see that thing surprise everybody you wheel with. i’ve been with 2wd tacoma’s that have a stock e-locker and they amaze me every time. Sent from my iPhone using Tapatalk
The results should be the opposite... what springs did you go with? is it springs and spacers or just springs? Sent from my iPhone using Tapatalk
are locking hubs worth it for me?
joshrichard replied to Strato_54's topic in 96-2004 R50 Pathfinders
I had a set of rugged ridge knock offs from eBay on my pathfinder. I don’t know what others would say about the durability of the construction, but if you’re mostly on the road then I think they would work well. They worked well for me at least. Plus for the money, I thought they were a great deal. I never personally had a problem with chrome peeling but I also only had them for about 4 months. My wheels also limited my choice of manual hubs considering I wanted to keep my stock rim and most others would not fit through the center of the wheel. https://www.ebay.com/p/27020837095 -
Sound right, MAF needs replacement?
joshrichard replied to DonutHands's topic in 96-2004 R50 Pathfinders
If that’s the code that popped up then it’s probably correct. I just recently replaced the MAF sensor and tube. What year is your pathy? Sent from my iPhone using Tapatalk -
zakzackzachary's 2000 R50 new to PNW from AK
joshrichard replied to zakzackzachary's topic in 96-2004 R50 Pathfinders
So. Many. Pathfinders. That’s so awesome man. I hope one day I can find a way to make it up there and finally be able to meet some of the faces behind the names! Also, your pathfinder is hands down one of my favorites. Everything you did, you did it so cleanly. Everything has a purpose and is functional. Crazy sweet truck man! Sent from my iPhone using Tapatalk -
800 has been the sweet spot for the two that I’ve had Sent from my iPhone using Tapatalk
Try a junkyard? Or search Craigslist for parting out pathies? Sent from my iPhone using Tapatalk
I cut out both the resonators and did a flow master. Absolutely love the sound. Deep and loud but it doesn’t bother anybody Sent from my iPhone using Tapatalk
Yes! got OEM so the spacer was already on there Sent from my iPhone using Tapatalk
So after doing the entire lift I would say that as long as you have the right tools then it isn’t too bad. With the back all I had to do was take off the shocks, and the sway bar end links and the axle dropped down just enough to fit the springs in with no problem. The front wasn’t too bad either but a million times easier with a friend. I did one side alone and the other with a friend and it cut the installation time to about half. Sent from my iPhone using Tapatalk
I’m so excited to take it out on some trails Sent from my iPhone using Tapatalk
How to fit 35’s: Slight rubbing Sent from my iPhone using Tapatalk
I am beyond excited to have been able to finish the lift today. She rides like a dream. Tires are 30.6 inches at the moment and plan to get some 32 inch MT’s Sent from my iPhone using Tapatalk
PathyDude's R50 Projects (03 SE 4x4)
joshrichard replied to PathyDude17's topic in 96-2004 R50 Pathfinders
Man i want some snow -
So i made a very last minute change. I decided to switch to the OME HD in the front. Mostly because of the amount of praise they get for ride quality. I’m going to be running the same setup as@zakzackzachary
i’m so excited man. The amount of research required for a lift on these trucks suited to the driver definitely brings a new level of appreciation towards the vehicle.
Struts are in, spring compressor gets here tomorrow along with the OEM strut mount + bearing, bellows, and bumpstops. AC and LR springs get here next early next week. Already have the Bilstein sitting in the garage. Gonna begin the Install next Wednesday, first day off for thanksgiving break.
is that the intake air tube above the left wheel on the 1996? if so i wonder why they chose to change to the big ugly white reservoir looking thing
Okay that makes more sense thanks
@RainGoat I just realized that a while back you directed me towards Desert Rat located in... Arizona I think? Well I was searching the website for AC springs for the front. I know that OME and AC are ARB, but again im confused. I was looking for the part number on 4x4parts.com which didnt help because all they have is the stock keeping unit. My question is, does Desert Rat sell the 2 in AC springs? they have a list of part numbers and the discriptions are very vague, not telling the amount of lift, or if its for the front or rear; only specifiying whether its for the R50 model and whether it is Heavy Duty or Medium duty.
