50
Everything posted by onespiritbrain
Seems like I remember the balancer had to be milled down for this very reason. Someone else will have to confirm but I think I remember that, in addition to the boar diameter, the mating surface had to come down also.
The flood sensor is a cool idea and I’m interested to see what you come up with to get it working well.
Spring Break 2020 Meetup (South)
onespiritbrain replied to Ole_Rosie_R50's topic in 96-2004 R50 Pathfinders
So what trails are we going to run? A great 3-4 hour run through north GA could be Dick's Creek(FSR164) to Popcorn Ridge(FSR163) to Charlies Creek and ending at Denton Branch Falls to camp. In the same area there is also Tray/Chimney Mountain and Indian Grave Gap. There is Cashes Valley Rd and Cooper Creek WMA a little further west. Then there are difficult trails like Beasly Knob and Nimblewill Gap where even Rubicons require winching. Heres a tour of the Dicks-Popcorn-Charlies-Denton run: -
I read that its only function is throw a code and doesnt cause the ECM to adjust fuel maps.
Lifetime guarantee auto parts store alternators are what I have always used. I can confirm that they suck. Cheapest chinesium bearings, extremely soft commutator, garbage brushes, wont last two years... but once you buy one you can replace them for free forever... Id rather have a high quality alternator but im not shelling out $300 for one.
Speed Dependent Whine Under Acceleration
onespiritbrain replied to onespiritbrain's topic in The Garage
The rumble is still there. I think it’s from the ujoints I replaced not long ago. They have play when shaken by hand. -
Double post -
For information purposes this issue was caused by low tire pressure. -
Wow I’d love to have that thing
VQ35 already has a 110A alternator. The Quest alternator puts out 125A. Not a big enough jump to me..
Transmission, Transfer case removal
onespiritbrain replied to pairrothead01's topic in 96-2004 R50 Pathfinders
It’s gonna suck. How bad is it leaking? -
FSM says it’s built into the ECM. You’re probably gonna have to either replace the ECM or open it up and desolder the component. If you can find a part number on it then you can search for it on amazon or alibaba.
Front diff oil was much darker. I think the rear oil looked darker because it had clutch material in it. -
These are all the ring gear This is the only good shot I could get of the pinion gear The oil smells like burnt clutch and is pretty dark but doesn’t not contain any metal shavings. Front is coming next. -
Pls delete
It should only take one turn in the unlock direction. The electrical portion of the lock cylinder is no good if it takes multiple cycles. Mine is on the way to being no good. Right now I can unlock the driver door without disabling the security alarm which causes the alarm to go off as soon as I open the door. Usually it only takes one turn in the unlock direction to get the alarm to turn off but here and there it takes multiple cycles.
No whining at all on the way home.... not complaining or anything. Rumbling was still present. The rumbling is not intense enough to rattle anything inside the vehicle but it does shake my side mirrors enough to where it’s hard to make out details, like what kind of car is about to pass my slow butt. -
Actually I just wiped what looked like shavings from the magnet and it was metal paste formed into spikes. So no visible shavings thus far. I have to get home and I’ll dig in tomorrow. -
I assume that amount is abnormal? I changed the drain plug out for one I have at work but there’s no magnet. I suspect there’s more metal in there than what can held on that little magnet anyway but I am just picturing newly freed shavings making their way into the mesh.. Is it of any benefit to change the fluid at this point? -
So a few days ago I went off-roading for the first time in a while. I didnt use 4WD and did have some free wheeling at the rear on the way off the trail. First I noticed a significant whine, about as high pitched as a deep males voice will go, at 50-60mph under heavy acceleration load (up a hill). Now the same whine is present when taking off from stop and increases in loudness until about 25mph and begins to taper off until 40mph where I can barely hear it. It still reappears sharply at 50mph going up hills. I would like to pinpoint the offending area. I hope its the transfer case since I have one sitting in my storage building but I fear its actually the rear diff. I do also have a slight rumble that is load dependent (more pronounced with greater load) that begins at 40mph and peaks at 50mph before tapering off to nothing by 65mph. I do not notice a change in the whine while taking curves. 70+mph speeds are silent and completely smooth. I plan to check fluids in both the rear end and transfer case tonight.
Unbelievable - 1991 SE Sells for $18,500 at Auction Last Week
onespiritbrain replied to mike1305's topic in General Forums
Wow! -
It looks like those little spacers are important... the new strut mounts I put in last time are now wallowed out. I locked the nut up top down as tight as was possible holding the shaft with channel locks but the rubber on the inside now spins around with the shaft. I cant tell if this is going to allow the whole thing to become dislodged again. Dang it..
Multiple issues going on at the same time can be so strange. How in the world does a covered radiator and a plug wire problem just so happen to present at the same time...? I've had similar stuff happen like that, multiple times. It can be quite the coincidence, of course I guess on an aging vehicle with thousands of potential problems lying in wait, it can be expected that multiple problems present at the same time. However I do not see the same pattern with industrial machines.
https://www.rockauto.com/en/catalog/nissan,2001,pathfinder,3.5l+v6,1432945,fuel+&+air,manifold+pressure+(map)+sensor,11207
