6
Everything posted by PINION
check under right side of tranny where slave is, and left side just below master is clutch
flush out old fluid, like break fluid, it has to be replaced. that should get you some pressure, if it looks like this, its burnt
Hey Kyle, I have the same pedal issue, just cant get it at the right adjustment. think im going for the "master" replaced the slave already. I'm also getting a "whirring" sound when it warms up with the clutch in in gear. Of course I did just drive it cross country and back this month.
I would say getting time for a new clutch. you might want to also try flushing the fluid from you clutch system. It is hydrolic. But it does sound like clutch. No issues putting it into 1st?
free facelift
this is what 250 miles in a snow storm looks like
need advice on replacing cv axle shafts
PINION replied to Megaton's topic in 96-2004 R50 Pathfinders
I second, or 3rd Kyle and Steve. I just did mine and went with new, not so cheap. The Black Yetti is worth it -
Techron is chevrons, I ran save the pieces (STP) , couldn't find techron on the road. and yes the filter change did the job. after that down shifting helped too
replaced the fuel filter roadside in Salt Lake, weehaa. much better. Although tires 3 ' bigger and loaded down with several hundred pounds of my sh#t doesn't help im sure, lol
so, I am 3/4 through my trip from ny to nv to the point Truck preforming wonderfly, not even burning oil today cruise on, 73 mph, 2700 rpm, throttle drops out like the cable snapped (wtf), if any one here has a manual you know how it feels when you just pull out of throttle. anywho, so I turn off cruise, and start loosing speed up hill, then up incline, ( in wy at this point, lots of incline) 1/4 tank of gas. no power when in throttle, no bucking or anything other then truck just slowing. on the flat god as long as I don't put full throttle. wnet and gassed up. went nice for 29 miles then same issue continues. againg no other symptoms other then all of a sudden fab fuel mileage. truck has power, just not under load. Im thinking fuel filter clogged. Did 80 for another 200+ miles. just no power under load.
ummm. im done, went with the ac, gr2 front bilstien rear 2"
2" ac with older tires, I now have 265/75R16 on it
the change in color tone is due to heat, the rear of the motor gets more heat. I would like to try the Seafoam, but where I live they would arrest you for the billowing cloud. Interested in other options too
could be a bomb...???
did you try replacing the knock sensor
E36 318ti w/s52 swap, E21 320i W m42 swap, 03 T5
hey Pat, using a pressure bleeder, no air in the system, thanks
Thanks, pedal back at the floor again today, still plenty f pressure though, will adjust pedal one more time
thanks, pedal back at the floor again today, hmmm, will try another pedal adjust, plent of pressure in the pedal.
The turkey baster is for removing all of the old fluid from the resivior. slave cyl is 14mm bolts, line at slave is 13mm banjo, line to line is 10mm, and bleeder is 8mm
Todays joy is brought to you by.... Shot slave cylinder. And so it begins, cause I like clutch The tools; 14mm socket,13mm socket, line wrench's-10mm ,8mm. Pressure bleeder( one of my fav toy's), synthetic fluid. Im going to flush the whole deal, cause the fluid is almost black. Thanks Rob once again for the right parts. I assemble line and slave cyl, to limit drip on floor I now have a clutch, yay Brake fluid is getting flushed too, also a bit burnt
Project Resurrection: The 98 Pathfinder
PINION replied to IchWarriorMkII's topic in 96-2004 R50 Pathfinders
Check in with Alkorahil, aka Rob on parts. I got my timing belt gear from him ( Nissan) and it cost about the same as the ebay price. Otherwise what everyone else said. Also flush out brake fluid, especialy if its brown in color. -
there are a few on Long Island CL in good shape, How far up are you
yes, off to the tire store tomorrow
