PINION
Everything posted by PINION
  1. if your not going to use that rear panard drop bracket, let me know.
  2. yes, an updated site would be great, those lines, what years and thanks, it is killing me waiting that long.
  3. Thanks, but I will be waiting to start till I get the balance of the parts from them. getting that with the "Package II" deal, as well as the sub frame cross member, Well I have a pile of parts till November I guess.
  4. poo, shut down till November
  5. not getting any response from kfab, anyone know a phone number or something. trying to buy a few things
  6. an extreme of re inventing the wheel, I know. but arent options fun
  7. yes, it is a rear diff, yes ours are offset, with a diff such as the one pictured, you could put it anywhere, as long as you can have axles made for it. Most baha buggys, and the alike have similar diffs. this was what I had in my garage at the moment. And yes, I used the wrong terminology, not a floating diff
  8. attached by bushing points, not cradled or solid fixed to subframe
  9. I was looking and think a similar thought, go with full floating diff, with beefed up axles
  10. chevy also runs a shortshaft front setup back in hotrodding days, Jag diffs were popular
  11. that where some homework and a welder come in
  12. ummmm, poop. I smell axle swap in the future
  13. going to do lift on 3rd pathy soon. Going to a 33 tire. last pathy with a 32 tire, speedo was way off, also manual tranny so no real loss of power. This one (98 se) is autotragic. So to the point. Does anyone have info on pinion gearing options and resources
  14. yes, Im looking for more then stock suspension travel so im going ome struts with the hd springs with 2" spacers
  15. yes, I know, going with 2 suspension and 2 spacer,
  16. I'm doing 4" sfd, with 2" springs and 2" spacers. looking at the BDS 3.5" wj springs for the rear. going for the extra buck with OME front gear, looking for 4.5" to 5" total, plus tire height, 33's
  17. Thanks Bushnut, that's what im looking for looked up Tough Dog, only 30mm lift. going to call OME again
  18. just checking to see if ome has more travel the gr2, called ome and their specs are 180mm of travel. Had gr2 on AC lift and the bottoming out was terrible looking for gr2 specs, cant find online point gr2 $50 each, ome 209 each, is it worth the difference with same travel??
  19. Ive had kyb, bottom out sucked, just looking to see if ome has more travel. big price difference
  20. anyone have the kyb gr2 open mm and closed mm comparing it to ome, open 590mm, closed 408mm
  21. to let anyone know, this recall is still on, doing mine this week.
