Nefarious
19
VG33 engine build (inc swapping out VG30)
Nefarious replied to PJpathy's topic in 90-95 WD21 Pathfinders
I personally just "massaged" the wd21 oil pan to fit the r50 oil pickup. Some calculated taps a ball peen and it fits perfectly. Did that for both vg33e swaps I've done now. Zero issues years and years later, just for future information. -
Technically December 21st is the first day of winter. Still haven't had any snow where I'm at, although it has been getting down to -13 or so some nights. As long as I get it finished before the snow hits, I'll be laughing... my lowered 240sx is not ideal in snowy conditions haha.
Just got the front of the engine back together. Just need to torque the crank bolt and put the belts/fan/rad/rad hose on! Then the restored brake booster and rebuilt brake master cylinder go in and she is done! Can't wait to get this truck on the road for winter...
You cannot access the plug that attaches to the knock sensor itself, and the other end of that harness is located in the bank of plugs where your injector harness plugs in. If you check the fsm there is a pin out of each plug. That will be your best bet for a clean look is to re route from there. Either repin the harness and swap in your own wire or cut and splice. In my honest opinion though, pulling the plenum isn't that bad...and once you factor in wiring time for the relocation, you might as well just pull the plenum and do it right. Either way will work, but it's only going to take an extra hour or 2 (depending on your skill) to do the job right. Might as well?
Very accurate analogy Mr. Precise. So true!
Harbinger's Automatic to Manual transmission swap.
Nefarious replied to Harbinger's topic in 90-95 WD21 Pathfinders
The starter grounds through its physical connection with the engine block. You just need to supply load power and the control wire to drive the solenoid. The small single wire off that loom hooks to your oil pressure dummy light -
haha well I just repainted all the parts black again and stripped the parts that were steel and used to be coated (and we're just rusty) with black as well (coolant pipes etc). I also polished and shined up some of the aluminum parts as well. I figure I'll start a build thread for my new truck in the members rides section. I'll get some pics tomorrow and post up a new thread!
Finally finished painting the last pieces I stripped for the timing job. Will have it back together and running on the weekend. Can't wait to get this truck back on the road with all the issues fixed! Miss driving a pathy...
Very cool. I've done the removable seat hinge thing for my rig for years now and it works great and only takes 1 minute to convert but you have to sleep between the wheel well humps. I like how your design moves the sleeping position above the wheel well humps to get maximum width. I was thinking of building some shelving like thst in the new truck to accommodate the full width of the rear while adding storage underneath. Like it man!
That's the nice thing about nissans. The 5 speed manual for the vg30 is essentially the same from 1986 to 2004 (vg30/vg33 equipped models). There were changes made alone the way but any of them will fit and function. Sorry I don't have any ideas as to why your trans won't go into reverse though.
no I have not! Never even heard of it.. is it some kind of spray or solvent, or is it an actual machine/process? I like to restore pretty much any piece that I pull for repairs so maybe I'll look into that. If it's easier than a nylon flapper wheel then I will be a happy man! Lol edit: oh man... just googled it... i am definitely going to try that next time! Looks very easy to setup your own rig at home for said electrolytic rust removal. Looks almost too easy! Thanks for the tip !
haha. Well at least now it shouldn't rub ! I'm running 2" fender flares on it and the wheels just poke out the slightest bit. Maybe 1/4" so it's pretty wide now eith the new wheel setup!
Stock idler arm with new oem nylon bushings and the idler arm brace. That's what I've used for years with 33s and never had an issue!
Ground down, sanded and painted a bunch more parts that I pulled to do the timing belt (balance tube, thermostat housing, etc). Then I rolled and pulled the fenders on my 240sx... hopefully no more rubbing when my hatch is loaded full of tools for work!
I love mine and the old lady loves hers in her rig as well. She used the moog problem solver parts and that thing is insanely solid.
Pathys are pretty good at major damage aversion due to the thicker sheet metal panels (the reason they called the pickup the hardbody was because of the thicker gauge sheet metal they used vs. The 720 pickup) but the problem is that there's so many flat spots on our trucks! If you walk anywhere near a corner joint of sheet metal, it's unlikely it will bend. I weigh 260 lbs and have walked all over my truck, but in strategic areas (along the sides where the sheet metal has shape) and never dented anything. I would never walk through the middle though !
Maybe the maf? Have you cleaned it? Check the connectors for loose pins ? Or possibly o2 sensor? Unplug it and see of the issue gets better or run the o2 sensor ecu diagnostic. (You have run the ecu codes, correct?)
Good luck and take pics!
Replaced the front cam and crank seals. Installed a new waterpump. Pulled the thermostat housing and coolant sensor housings to clean and paint. Just about ready to reinstall the timing! Stoked to get this truck on the road for winter.
You can trim the fender flares to fit 33x12.5s. I run 33x12.5 on a 15 x 10 wheel and even with the short steering stops for max steering angle I do not rub at all. The main place for pathfinders to rub big tires is the front pinch seam of the chassis inside the rear of the front wheel wells. I sliced out the pinch seam and shaped it back a bit and then welded the seam shut and coated it with rust protect and then under coat. On top of that I trimmed the edges of my fender flares on the lower sections closer to the bottom of the truck. I think I may have had to trim a tiny bit in the rear too but that was very minimal. I can completely stuff my tires on my rig and have the wheel turned fully and no rubbing at all. 3+3 lift.
That's why I went with the 2wd swap. The system inherently has less bump steer and greater steering articulation. No off the shelf tie rod re locators that I know of.
Pulled the camshaft and crankshaft seals... 350k km on engine and I think they were original, rubber had turned into hard plastic consistency and it took me 2 hours and much cursing with all the right tools to get the 3 seals out. I've done this job a few times before on my other rigs and never had any issues, but this one I will remember. Good thing this new trucks body and frame are so mint cause that engine was seriously neglected! I am bringing it back up to snuff though... the leaks in the brake system and the front of the engine are just about fixed.
Cleaned the front of the engine of all the oil and grease and gunk after the years. Finished painting the timing covers, gave one more coat to the brake booster.
Manual Trans vehicles typically come with the 4.3 ratio front and rear diff gears. Automatics came with the 4.6 gears. This is not always the case but has been true in all of the pathfinders that I've ever seen. The 4.3 ratio in the manual trucks is used since the manual trucks inherently make more power to the ground through less drive train loss and can push a slightly taller gear set with the same effort. The autos were given 4.6 to help mask the effect of the power sucking automatic transmission. The automatics Rev lower going down the freeway because of the much taller final drive ratio of the auto Trans' vs the manuals 5th gear. My girls 1993 pathy came stock with 31" tires, manual Trans, and 4.3 gears. My 93 auto came with 4.6 gears and 235/75 tires. My 92 auto came with 4.6 gears and 31" tires.
New rear bumper for my "95 WD
Nefarious replied to Manik's topic in Solid Axle Swaps, Hardcore Custom Fab
Just a quick comment, love the work; but I would add some extra reinforcements to the rear bumper mounting system if i were you. The bolt on hidden hitch for a pathfinder is exactly what I'm going to copy as a reinforcement method. The rear frame tapers down to a c channel rear section which is quit weak when coupled with a heavy rear bumper with integrated tow hitch (ask me how I know). I am going to add some reinforced side to side trusses integrated into my rear bumper brackets to combat this issue. Seeing and feeling the trailer bounce just because of weak rear frame points is disconcerting if you plan to actually tow with your rig!
