csutke
Everything posted by csutke
  1. should i spend the extra money and get synthetic?
  2. I have a auto tranny and believe that I have tranny fluid in the T-Case
  3. So im going to need to be changing all the fluids in my rig and its prob never been done and it just turned over to 70k miles. I have looked at the FSM and think that i have a pretty good idea as to what needs to be done but i still have a few questions. 1: When draining the coolant is it really nessacary to drain the coolant from the block as well? and im kinda lost on the steps of doing this. 2: What fluids do you recommend for Tranny, T-Case, Front diff and Rear LSD diff? 3: Any tips or trick to know about? 4: How long should something like this take to change out Coolant, Tranny, Front/Rear Diff, T-case? 5: Does checkers or other parts store recycle used coolant etc...? Thanks
  4. What year, and model? Could be bad plugs, wires, timing may be off, etc...
  5. If you have one which one and why did you pick that one? Any suggestions as to which one to get? Also does any one know if theres a reciever that has an output on it or a way to make an output instead of using the FM transmitter as I have two AUX inputs on my deck? Thanks
  6. lookin good, your location says that your from WI but the plates on the truck are from CO, so which is it?
  7. that could defenitly do it. I would make sure to change the wires before going on your trip
  8. tow hitch, jumper cables, tie downs, 4 way, tow strap. etc
  9. So my biggest question is how to make the liner stick to the chrome? Should I also do the plastic as well and if so how should I get it to stick to the plastic? Looking a new bumper replacements online the run around 300ish so doing this is way cheaper.
  10. i wish, but that prob to spendy right now
  11. So Ive started to get some rust on my front bumper, so this gives me an excuse to finally A: get new bumpers or B: make them black to match the rest of the truck. Id much rather herc them over painting them but if painting them would be easier I might do that. So my questions are what would be involved in hercing or painting my bumpers? Would I have to remove the bumpers to do so? And will either paint or herc stick to chrome and for how long? Any ideas, tips greatly welcome. Thanks
  12. the hubs might work if the center bore is big enough but you will have to lose the center caps as for the tires you will have to go to a metric size with a 16" wheel the closest size to a 31x10.5 is 255/75 R16 that will put you at 31.1x10"
  13. Did anyone else have troubles this morning? I tried to load it and it said that the account was suspended.
  14. so you got the front diff out of an X? didnt think that would work as we have a high pinion.
  15. mine leaks a little coolant but not a lot, you may even want to check a junk yard
  16. mine's bad as well, just haven't got a chance to change it yet, ill take a pic of it tommorow for ya. you can find them at http://www.courtesyparts.com/betasite/1618...cPath=4700&
  17. no the struts cqn not be mounted backwards. Wow 2 months is a long time to have those tires like that, there prob goona be shot now and will not even out.
  18. So after a friend yesterday change his plugs, cap and rotor, I have come to the desicsion that bosch plugs are crap and I will never buy them again. So here the story. Got the cap and rotor done, easy. Then started on the plugs got 1,3,5 done could have been easier casue the last person who put the plugs in didnt use anti-seize. Then moved on to 2,4,6. started to work on number and 2 this happened, these plugs were bosch +4 but all that was left was the ceramic, the threads had become detached and were left in the cylinder.
  19. ok cool, thanks that should help me save some money, i had looked at them before but couldnt tell if they came with bushing or not but that clears it up.
  20. yes i bought them at tynans but the only problem is Ive already bought them so....
  21. so you postive that these arms come with bushings? reason being is i just bought two arms from the dealer for $120 each. The reason that I bought them from the dealer is that it was the only place that i was positive that that the arms came with bushings, so if you sure that these arms come with bushings i will try to return them and get them online. Thanks
  22. at least this hasnt happened to any of you, our gang just lost 300 mil to some douche bag http://www.4x4country.net/forums/viewtopic.php?t=1301
